It is currently Thu Nov 05, 2026 4:36 pm
Vehicle: 82 Sierra SWB soft top
Post Posted: Fri Mar 29, 2013 11:44 am
Took this bar of my parts car becaus i wasnt happy with my dogey homemade crap, looked good in the photos thats about it, it's roughly 3.5mm aloy it was a 6point cage but I took the rear section off due to I'm going to run a ute style soft top, my question is should i add a braces somewhere to retain abit more strength was thinking of adding a bar from the up right section in the cab back to the parts that come back at roughly 150mm above the tub. For a tie down point but a structural brace would be best. I'm sure fat zook will chime in and help here (I'm hoping anyway)
I'm guessing strongest option would be a top corner to bottom corner type deal.
Doug
Post Posted: Fri Mar 29, 2013 3:45 pm
unless the main hoop has a cross brace it is near useless
Post Posted: Fri Mar 29, 2013 4:14 pm
Something like that with a plate to bolt to the floor.
Post Posted: Fri Mar 29, 2013 4:21 pm
personally id do one the other way in two halves welded to the other one
form a cross. im not a fan of bolted braces but each to heir own just make sure they are rated bolts not hardware grade shit
Post Posted: Fri Mar 29, 2013 4:25 pm
this is mine
its been tested seveal times :lol:
