It is currently Wed Nov 04, 2026 2:50 pm
Vehicle: 85 WT with SR20DE N/A
Post Posted: Sun Mar 31, 2013 8:15 pm
Hey guys,
I have been trying to get the flange off the diff on the car are there any tricks that people have I don't have an air compresser
Robbie
Vehicle: 1.3 Tin Top
Post Posted: Sun Mar 31, 2013 8:26 pm
have u got the nut off?
if not just use a breaker bar.
once uve got the nut off. spray some wd40 on the splines.
tap the back of the flange, top and bottom with a hammer (soft faced if uve got one)
should come off
Post Posted: Sun Mar 31, 2013 8:29 pm
should come off
That is what I am trying to get off I have used a braker bar but it wont budge
Post Posted: Sun Mar 31, 2013 8:31 pm
Breaker bar and long pipe onto breaker bar.
Post Posted: Sun Mar 31, 2013 8:35 pm
I tried that but hard to get much leavage under the car
I will try again tomorrow
Post Posted: Sun Mar 31, 2013 9:30 pm
Use a piece flat bar or similar like this to stop the flange from turning.
viewtopic.php?f=17&t=36468&hilit=+flange+removal
Post Posted: Sun Mar 31, 2013 10:01 pm
is there away to do that why it is still on the car
Post Posted: Sun Mar 31, 2013 10:07 pm
Get a length of bar long enough so that it hits the chassis rail or the ground.
Post Posted: Sun Mar 31, 2013 10:15 pm
thanx heaps RED 89 will do this tomorow
Post Posted: Sun Mar 31, 2013 10:17 pm
Make sure you pop out the little indent.
As others have said, breaker bar and pipe.
If you get real desperate, soak it in WD/CRC overnight, put your breaker bar and pipe on, lock the front hubs and try to drive it off ;) make sure you drive the right direction :lol:
Post Posted: Sun Mar 31, 2013 10:19 pm
ehat you mean pop the little indent
Post Posted: Sun Mar 31, 2013 10:38 pm
the outter part of the nut has a ring around it that is dented??? into a mating notch on the pinion, thus locking the nut. Clean and look, it will be quite obvious. Mark nut position before dissassembly.
Breaker bar, get a solid foothold and but your back into it........it will undo.
Post Posted: Sun Mar 31, 2013 10:40 pm
What he means is there's a two little notches on the piƱon that the bolt locks to if you look at it face on you'll see em... There's two oppersit each other
Beat me to it
Post Posted: Sun Mar 31, 2013 10:46 pm
Thanx heaps guys
that is prob the resin I could not get it off spent hours trying to get it off lol
I will look first thing in the morning thanx again
Post Posted: Tue Apr 02, 2013 8:54 pm
try a spray by loctite called freeze this should also loosen nut and flange
josh AKA Bazook
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 74 guests
