It is currently Wed Nov 04, 2026 6:52 pm
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Mar 30, 2013 9:22 pm
As the title suggests is it possible to get the lights to turn off when u turn off the ignition? ???
Post Posted: Sat Mar 30, 2013 9:27 pm
The simplest way to do this would be a relay which would break the headlight circuit with the ignition off. You would have the choice of wiring it into either the accessory or ignition circuits depending on when you want to be able to turn them on.
Im not sure if there is a roadworthy requirement of being able to turn on the lights without the key though.
Post Posted: Sat Mar 30, 2013 9:32 pm
fit a headlight buzzer/reminder from jaycar.
Post Posted: Sat Mar 30, 2013 9:50 pm
Redarc do a 'Headlights On' system, comes on a few seconds after start up then turn off with the key. You've probably seen a few at work anyway. Do you want something similar to your Subaru?
Post Posted: Sat Mar 30, 2013 10:15 pm
yer man exactly scrawn you hit the nail on the head its just the negative switching that still gets me :( (still learning)
Post Posted: Sat Mar 30, 2013 11:32 pm
I had one of these. Something went wrong with it and it beeped when ever you turned the lights on, then it got worse and just beeped all the time. :x
Post Posted: Sun Mar 31, 2013 8:20 am
I was hoping there was a way to rewire it so its turns off like a subaru
Post Posted: Sun Mar 31, 2013 8:37 am
Do you want it so you cant leave the lights on accidently or so the lights are always on when you are driving?
It would be somewhat straightforward to make it so the lights cant come on if the ignition is off, but I think that isn't legal
Post Posted: Sun Mar 31, 2013 6:09 pm
The secound 1 why isn't legal though?
Post Posted: Sun Mar 31, 2013 6:14 pm
Something about parking lights being available all the time, if lights could only work with the ignition on, believe me they already would
What you want is an automatic setting for the lights, these work with the ignition but can still be manually turned on with the key off, so its a bit different and a lot more complex
I would say a DRL controller could work, but your lights will then ALWAYS be on with the engine running
A reasonable compromise might be to wire an ignition switched relay into the parkers, so they always come on like an old Volvo
Post Posted: Sun Mar 31, 2013 6:23 pm
Always on would be fine as long as the lights could take it
Post Posted: Sun Mar 31, 2013 7:38 pm
Get the Redarc system then. The lights will be fine. If you can't twist someone's arm at work to wire it up bring it over to me
Post Posted: Mon Apr 01, 2013 8:56 am
A relay as suggested should work but the old 2 series Volvo's didn't use the parker lights as DRL's. They were a seperate circuit with their own bulbs.
Post Posted: Mon Apr 01, 2013 12:50 pm
something else to consider, a stock sierra alternator wont keep the battery charged at idle and low rpm with the lights on
Users browsing this forum: Google [Bot] and 201 guests
