Joined: Mon Jul 30, 2012 8:49 pm Posts: 518 Location: Canberra ACT
Vehicle: Lwb vit, 31's big white fridge
Posted: Wed Mar 27, 2013 11:26 pm
Hey, So I'm looking to upgrade my starting battery in my LWB vitara.
Question is, what's the biggest sucker I can squeeze in there?
Ill also be running my winch off it and linking the starting battery with my auxiliary together via a kill switch when winching to give all the amperage I can to the winch.
There is usually room to get a wider battery in, but not a longer one. Height is important, as it could hit bonnet. Insulators on terminals is wise if in doubt.
Most decent after market batteries are perfectly capable in stock size(in my opinion) Optima is a good choice.
Posted: Mon Apr 01, 2013 9:29 pm
I'd like to squeeze the biggest battery I can in there that has the highest CCA rating, when we do our winching for advanced driver training with the club I'm wanting to give the winch all the current it can have, so ill link my auxiliary to it with an isolator switch when winching and have 50mm2 cable running from the battery to the winch so it has the freedom to draw all the amps it wants and can work effectively.
Do you think it's possible to squeeze an N70 sized battery in there?
Users browsing this forum: Google Adsense [Bot] and 230 guests
