Joined: Sun Jun 07, 2009 11:30 pm Posts: 573 Location: Perth WA
Posted: Tue Jul 14, 2009 11:45 pm
Hey,
Made up some extended shackles on the w/end. I used 8mm flat bar, with 90mm x m10 bolts. The problem is i cant find any tubing to use as crush tube that will fit over the 10mm bolt but also in the bush ~13mm. What has everybody used? Ive currently got some ali tube that was in the shed that fits but id like to try get some steel. The 12.7mm tube at the steel shop only fits a m9 bolt?
Users browsing this forum: ProteinDrinker and 224 guests
