Vehicle: 1994 Suzuki Sierra 1.3
Posted: Wed Apr 10, 2013 6:22 pm
I've got a g13ba in my garage I'm pulling apart and I'm having Trouble removing the crank shaft because I can't remove the crank Pulley bolt at the front. Any tips on how to get it out?
The outer pulley comes off by removing the 5 little bolts. Then you'll need an impact gun to undo the centre bolt. You may be able to somehow wedge a pry bar onto the flywheel and use a breaker bar on the crank nut but I don't like your chances
Get one of these, best $80 I ever spent. I use it for anything and everything. Don't know how I lived without it.... Well slowly, painfully and with much swearing.
have yet to do it on a suzuki but it worked on my sisters hyundai (engine spins same way) just bump the starter. I wish i had of known this a few years back when i was pulling apart a junk g13a. i had used a long tube and breaker bar and a block of wood inside jamming the crank.. even after all that it was not easy
Had the same issue recently when replacing the head gasket. Used a blow torch to heat the nut then impact gun. Sure it stuffed the seal behind it but this was replaced anyway.
Joined: Sat Feb 04, 2012 7:11 pm Posts: 1105 Location: Oberon, NSW
Vehicle: Drover pickup turk
Posted: Thu Apr 11, 2013 7:57 am
Not having an impact gun, I used a length of flatbar drilled 2 holes closer to one edge for the bolts then used a file between the 2 holes so that I could get the socket on.
Users browsing this forum: Google [Bot] and 171 guests
