It is currently Sun Aug 02, 2026 3:13 pm
Vehicle: 2004 Jimny 1.6
Post Posted: Fri Apr 12, 2013 4:47 pm
Done a search can't find the info I'm looking for.
What's the ideal Jimny wheel offset with 2 inch suss lift and 235/75 r15 tyres,
From research possibly -12 or -13, widen the track a little, not place to much on the kingpins or wheel bearings.
Need some advice to clear this up.
Vehicle: 2011 Jimny
Post Posted: Fri Apr 12, 2013 7:00 pm
As a idea I have -13 sunny and all that sticks outside the guards is the tapered edge from the tread to the sidewall ( on mud tires)
From memory it was about 6mm from the widest point of the wheel arches to the sidewall of my tires.
Post Posted: Sat Apr 13, 2013 1:35 am
15x7 -13 is a good offset for a jimny. I had 15x8 -28 and that was a bearing killer/ guard eater :lol:
Post Posted: Sun Apr 14, 2013 6:01 pm
15x7 -0 don't fit, but -13 does.
I run 15x8 -23 everyday onroad with 31s, and I have beadlocked 15x7s the. 15x7s fit allot better...
Post Posted: Tue Apr 16, 2013 9:11 pm
How wide are the standard rims?
Post Posted: Tue Apr 16, 2013 9:12 pm
What size are your tyres?
Post Posted: Tue Apr 16, 2013 9:23 pm
5.5" are your standard rims
Post Posted: Tue Apr 16, 2013 9:50 pm
So a 15x7 - 12 or -13 with 235/75 r15 should be sweet?
Vehicle: MG410
Post Posted: Tue Apr 16, 2013 10:21 pm
-13 is the most common offset
Vehicle: 2011 Jimny
Post Posted: Wed Apr 17, 2013 6:52 am
30x9.5 I will double check this today. I have a picture aswell to give you an idea.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Apr 17, 2013 8:13 am
15" -15mm offset and 30/9.5km2's stick out the origional guards, so ill give flexy flares a go.
Post Posted: Mon Apr 29, 2013 8:41 pm
Pics? I'm still trying to get an idea of what mine will look like.
What real difference is there between a -12 and a - 13? Why does 1mm make a difference?
I trying to figure out why ppl would make almost the same rim, and the affect it would have on my car.
Post Posted: Tue Apr 30, 2013 7:55 am
Difference in someone measuring it with a ruler or difference in a jig to make rims. Dunno.
1mm will make 1mm of difference. (Don't worry your little head about it)
Post Posted: Tue Apr 30, 2013 12:59 pm
It's too late I already have lol
Users browsing this forum: Google [Bot] and 295 guests
