It is currently Thu Nov 05, 2026 12:23 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Post Posted: Thu Apr 18, 2013 12:22 am
Can twin steer be engineered and what would I have to do to get it engineered ?
Post Posted: Thu Apr 18, 2013 12:24 am
What is twin steer?
Do you mean rear steer? If yes, then No.
Post Posted: Thu Apr 18, 2013 12:30 am
I think I will have to look into this further
Post Posted: Thu Apr 18, 2013 12:35 am
8O :? :lol:
Post Posted: Thu Apr 18, 2013 12:45 am
THIS has rear steer, and is allowed on the road under a limited registration. SO if your vehicle looks the same, then you're in with a chance! :wink:
Post Posted: Thu Apr 18, 2013 4:53 am
U could try and use a electric actuator instead of a hydro ram
That way u could say that there is a physical connection not just hydro
Rear steer is legal if done right as some cars come with it from factory
It would need some way of self centering and a lockout for over a certin speed
There is a defender with rear steer that just has bolts that go through some plates to lock it up
It was in 4wd mothly
Post Posted: Thu Apr 18, 2013 7:35 am
Its possible to engineer it. I just think it would be a pain in the ass.
Vehicle: LJ80 Stockman
Post Posted: Thu Apr 18, 2013 7:38 am
My Uncle had a rear steer third generation Honda Prelude, so as got_bar_work said, it could be done, if done correctly.
Post Posted: Thu Apr 18, 2013 7:42 am
The hondas and celicas etc also only have like 3deg of turn at best. A steer diff in the rear could have up to 70deg.
It has been done. But I don't think it should be done.
Also, in your car bennyzarb I reckon you'd flip it 1000x quicker :lol:
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Apr 18, 2013 2:01 pm
telstar/626 1993 model, with RS turncircle 9.8m without 12.3. no idea how it worked, mine didnt have it. fellt like you were doign a uturn in a bus
Post Posted: Thu Apr 18, 2013 2:19 pm
This is engineered for queer steer...
http://www.ebay.com.au/itm/200912344440 ... 1423.l2649
Post Posted: Thu Apr 18, 2013 2:33 pm
Rack and pinion in the rear.
Post Posted: Thu Apr 18, 2013 3:05 pm
But how is operated, electric or hydraulic? The passenger car versions were speed dependent and changed direct depending on speed
Post Posted: Thu Apr 18, 2013 3:33 pm
How is it operated in which car?
Post Posted: Thu Apr 18, 2013 4:50 pm
My 300ZX had rear steer (HICAS). Max steer angle was 7 degrees. At 100kph it was locked out.
This is NOT the same as having a solid steer axle that can achieve 50 degrees lock.
Post Posted: Thu Apr 18, 2013 5:08 pm
And that's the key - there's no user input. There will have to be lockouts etc to prevent accidental application of rear steer. I'm sure it's possible, but it's going to be a LOT of work for something that's of more theoretical advantage than an actual advantage. Have a look at the results of TT to see that there were some very high placings from cars with no rear steer. I vote poor return for investment to make road legal.
Post Posted: Thu Apr 18, 2013 5:23 pm
Cos from seeing it happen it can get pretty ugly when you knock the lever at speed 8O The other thing to consider is you will need a fair bit of panel work done to the rear to accomodate the tucked wheel being turned which is why most simply remove the panels altogether.
Post Posted: Thu Apr 18, 2013 5:30 pm
Yeah, a line blew on the buggy at speed once, snapped full lock to one side. Would be interesting on the road! :lol:
With a sierra chassis, there is no room for it to be useful let alone the panels.
Post Posted: Thu Apr 18, 2013 5:50 pm
A mate barrel rolled at around 70kph when he hit a pot hole on gravel and bumped the indicator stalk that controls the rear steer, both him and his passenger were only wearing the lap part of their harnesses, his passenger hit his shoulder on the ground as it went over and broke his collar bone.
Post Posted: Thu Apr 18, 2013 8:33 pm
broken collar bone from a 70km/hr rollover with only a lap belt... sounds like the car was pretty well engineered to only do that amount of damage to the occupants!
Post Posted: Fri Apr 19, 2013 4:43 am
I would imagine if it has rear steer it has a cage alien...
Post Posted: Fri Apr 19, 2013 5:01 am
Thats y i said use a actuator as it cant move unless power is put to the motor
And being electrical it would be easy to get a control box made that had a speed input and would just lock it center over like 20kmh
Would need some sort of limit switches but wouldnt be that hard
Post Posted: Fri Apr 19, 2013 5:45 am
I reckon just leave the rear steer to the car on the trailer :)
Vehicle: SJ80, SE416
Post Posted: Fri Apr 19, 2013 12:28 pm
I'm pretty sure the HICAS systems on the 300ZX, skylines etc. had a maximum movement of about 1 (ONE) degree only. It's purpose is for stability control during high speed cornering.
Post Posted: Fri Apr 19, 2013 12:30 pm
Missing a digit there Reubs.
Taken from Wiki.... "HICAS and Super HICAS rear wheel steering is limited to about 10 degrees in either direction"
http://en.wikipedia.org/wiki/HICAS
Post Posted: Fri Apr 19, 2013 12:39 pm
the 4ws system on the mazda's switched from rear steer to crab steer at around 35kph from memory, was only around 5 degrees but was still pretty cool to park & crab steer high speed overtakes were cool.
Post Posted: Fri Apr 19, 2013 1:26 pm
Nope. 1 degree only. HICAS is stability control and in no way is rear-steer.
I don't want a p***ing competition so here's some 'tech'.
The HICAS brain (the ECU found in the boot near the battery (R33 models) gets it information from sensors that monitor the steering angle, the speed the steering wheel is being turned and the cars speed. From this information the brain works out how much steering input to apply to the rear wheels. This then operates a solenoid valve that controls the flow of oil to the rear steering actuator. This is linked to the wheels a bit like a normal steering rack via a pair of track rods. The only difference is the amount of movement allowed. A maximum of 1 degree of lock can be applied at low speed and only 0.3 degrees at higher speeds. Find below a video of a 300zx in diagnostic mode showing you Maximum movement while stationary
http://www.gtrpwr.com/showthread.php?t=1295
The vid showing maximum movement and some 'good tech' is here.
http://z32.wikispaces.com/HICAS
Post Posted: Fri Apr 19, 2013 1:36 pm
Well mine must have been played with in the motherland, because it achieved far greater than 1 degree!
HICAS eliminator kit was the best thing I ever fitted to that car!
Post Posted: Fri Apr 19, 2013 2:46 pm
Seen a srecthed Hummer the other day with around 15deg of rear steer at a guess from seeing it at full lock ....must be handy for the maccas drive through after a wedding :lol:
Post Posted: Fri Apr 19, 2013 2:57 pm
Actually I've seen that too! I guess when you are trying to engineer a vehicle that has a wheelbase 4 times the factory measurement, rear steer would be the least of your issues!
Users browsing this forum: No registered users and 73 guests
