Just looking to get a new set of rear springs for my LWB and noticed there is a difference in SWB->LWB well the code is different anyway. SWB Code= suz-008 LWB Code= suz-009
Is there a difference between the two? Thinking there might be as the -008 are shagged only after a very short amount of time on the LWB, less then a year of Road Use. I have gotten eye-eye measurements or anything to compare the two. Any input would be appreciated.
The LWB rears will have a slightly higher rate because a LWB is a little heavier than a SWB. LWB load capacity is actually less than a SWB though.
Ok thanks. Thought it was strange that they have a lower weight capacity kinda of a fuck up on Suzuki's behalf I reckon :s ill go with the correct spring as I plan on adding a bit of weight in the back any way.
Users browsing this forum: Google [Bot] and 38 guests
