It is currently Thu Nov 05, 2026 11:00 am
Vehicle: jimny
Post Posted: Fri Apr 19, 2013 7:37 pm
Boys, I've searched! Too much crap to sift through on here these days!!!!
Does anyone have a diagram to go off that is for a standard set of spotties into a Jimny? Or even the old diagram we used to have on here for a sierra will do, I've used it before and it worked fine, I've been in the tech section and I'm not interested in all the bullshit and people's led bar installs and 36 spot lights on the roof with diagrams that might work, just a clean and decisive wiring diagram will suffice, if you have no idea what your talking about please don't post your opinion so this means some of the old
Crew like Stekky, Royce, Atari, fatzook or fuck it even Shep please help me out and post up a link to the old thread or a new diagram..... Rant over ......... Shep bring back the milk crate ffs
Eldo
Post Posted: Fri Apr 19, 2013 8:01 pm
All here n00b
viewtopic.php?f=17&t=1108
the short of it, get some thing twin core wire and run some from the drivers headlight up to where your relay is, run another bit from your switch to the relay
at the headlights end, join each wire to a vertical pin on the headlight plug, 2 pins, 2 wires :)
at the switch end same, 1 wire to each terminal on the switch
now the relay
take a single wire from the headlight run and one from the switch run and join them together
the remaining 2 single wires (one from each twin) plug one to 85 and one to 86 shouldnt matter which way but if you have a diode protected relay and it doesnt work swap them
then connect pin 30 to battery positive via a fuse and the lights to 87
simple
you know jimnys are a bit feminine don't you?
Post Posted: Fri Apr 19, 2013 8:04 pm
EDIT: beaten by royce :wink:
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Apr 19, 2013 8:26 pm
Oi!!! :thefinger:
Vehicle: jimny
Post Posted: Sat Apr 20, 2013 3:24 am
Lol thanks Royce , I knew you would help me out now lock this thread and put it I. Tech FFS before some ricer gets in here and tells me how his fully sik sierra has a light bar and 39 spot lights on the roof and does skids in the car park at woolies..... Oh and yes jimnys are a little feminine I know.....
Vehicle: jimny
Post Posted: Sat Apr 20, 2013 5:18 pm
All sorted now boys
Post Posted: Sat Apr 20, 2013 5:22 pm
Armsup thread needs more milk crate.
Vehicle: jimny
Post Posted: Sat Apr 20, 2013 7:20 pm
Thanks Atari ..... Is that a milk crate statue of Shep
Users browsing this forum: No registered users and 91 guests
