It is currently Wed Nov 04, 2026 6:31 pm
Post Posted: Sun Apr 21, 2013 9:37 am
I have cooked my handbrake. Transfer case mounted unit.. Have removed tailshaft. Is the drum just located on the studs like most rear drums or do I need to remove the centre nut and dismantle whole unit. My manual only shows rear wheel handbrake.
Post Posted: Sun Apr 21, 2013 9:42 am
Yes, drum should be loose. Give it a tap with a hammer
Vehicle: Drover pickup turk
Post Posted: Sun Apr 21, 2013 11:46 am
I like the tuna here
Post Posted: Sun Apr 21, 2013 12:51 pm
Both the handbrake drum setups I have are different to that. On mine the drum locates on the transfer output spline and the tail shaft bolts straight to the drum ie no flange.
Post Posted: Sun Apr 21, 2013 12:54 pm
So you've got to undo the centre nut then?
Post Posted: Sun Apr 21, 2013 12:56 pm
Yep. Remove tail shaft then centre nut and a bit of wd40 on the spline and the drum should slide off.
Post Posted: Sun Apr 21, 2013 1:02 pm
Mine is like Sheps too.
Post Posted: Sun Apr 21, 2013 1:41 pm
thanks for the responses.
Shep is on the money, his description fits mine. does anybody have a second hand drum and shoes for sale, mine is toast
Once again thanksfor the help.
Macca
Users browsing this forum: No registered users and 191 guests
