It is currently Wed Nov 04, 2026 4:19 am
Vehicle: 2006 Z Series Jimny
Post Posted: Sat Apr 27, 2013 10:35 pm
Hi,
My 2006 manual Jimny has a noticeable rattling/whining sound when revving over around 2200 rpm in 4th gear 2WD. It is also noticeable in 3rd but not as bad.
The noise completely disappears when shifting into 5th and is also not at all noticeable in 1st and 2nd gear.
I had a good read around the forum and found a similar post where they were trouble-shooting the possibility of it being the engine "pinging" under load and recommending using premium unleaded to see if it helps but I run the 95 or 98 stuff already.
What do you guys/gals think, gearbox/tcase stuffed ? Or heading in that direction ?
Have any others had this?
thanks for looking, cheers
Vehicle: On the lookout
Post Posted: Sun Apr 28, 2013 10:18 am
If it's only in 3rd and 4th then my bet is rear main bearing in the gearbox. I had identical symptons to what you just described. Take it to a garage, they'll test drive it and tell you what it is for free probably. Then if it is the gearbox you can whip out the gearbox yourself and take it to a Gearbox and diff specialist for repair. It'll cost you about $700 if it's what I think it is. Plus $200 for a clutch as you might as well put one in while you are down there.
Mine did the same - 3rd and 4th. It'll get worse quickly, so don't hang around. It's not serious to start with, but in about two weeks mine evolved from whine noise to full 'rattle-about-to-explode' noise.
Mine had only done 60,000kms of gentle driving, so it's obviously a fault of somekind, not just general wear and tear. It's reasonable to think my Jimny isn't the only one that could develop this prob.
Post Posted: Sun Apr 28, 2013 3:01 pm
Thanks squibbly, damn I was hoping for better news but my gut tells me your right.
Will get it to a mechanic tomorrow for opinion as you have advised, no way I can pull this out myself so better start saving big time and fast by the sounds of it
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Apr 30, 2013 9:16 pm
my vvt box is pretty noisy in 4th, and its only just done 12000k. 9000 of that has been on the Central Arnhem highway though...
Post Posted: Wed May 01, 2013 12:58 pm
Hwdy Jezza86, does the noise completely disappear when shifting into 5th? and is there no sign of it in 3rd?
cheers
Vehicle: 2004 Jimny 1.6
Post Posted: Wed May 01, 2013 6:50 pm
Sounds normal lol, a whine in 4th and 5th is standard the rattling is bad. If your in Perth I'm happy to help mechanically
Post Posted: Thu May 02, 2013 5:28 pm
Agree, you need a bit of 'rattle' definately. By that time you ain't got much of a window to get it fixed. Maybe like 50kms max or it'll cost you.
Post Posted: Thu May 02, 2013 5:48 pm
Hi,
thanks for responses and Perth help offer but i'm up in Darwin :(
Mechanic checked it out today and thinks that it'll be cheaper to hunt around for a low km second had one that get this one rebuilt up here.
So far can only find them for $2000+ 2nd hand and of course would then be worried I'll be up for another one again in 20,000 ks etc.
Can anyone one recommend someone rebuilding them etc maybe exchange? At least that way it should last for awhile, or spotted any low km ones I could get shipped up here?
Also is it tricky to switch to auto in the > 2005 VVT models from manual do you know?
Cheer and thanks again for responses people
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Jun 17, 2013 9:21 pm
missed that sorry, yeah it disappears in 5th, 4th is just noisy has been since i got it with 2000k on the clock.
id say take it to a gearbox place not just a mechanic. fixing it may be cheaper.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 66 guests
