It is currently Sat Aug 01, 2026 8:55 am
Post Posted: Thu May 02, 2013 11:07 am
does any one know of the possibility to buy a new jimny crownwheel and pinion?
mine is getting a bit on the noisey side of life!
Phil
Post Posted: Thu May 02, 2013 12:07 pm
Genuine would be my guess. $$$$$$
Perhaps you should just pick up a used one.
Post Posted: Thu May 02, 2013 12:14 pm
Maruti rear. Front? bad luck.
Post Posted: Thu May 02, 2013 12:23 pm
Are you sure its not just the bearings getting noisy? Have you pulled it out and taken a look at the teeth surfaces?
Post Posted: Thu May 02, 2013 1:14 pm
Just pulled it and TBH the teath look good! i have ordered a master rebuild kit, so hopefully i have it back on the road buy the weekend or early next week!
Vehicle: '94 suzuki maruti
Post Posted: Thu May 02, 2013 2:45 pm
ones 4.09 and ones 4.11 IIRC, i think i remembered reading an argument on here about it... i don't remember which way around
Vehicle: '96 LWB trayback
Post Posted: Thu May 02, 2013 4:08 pm
Both are 4.09.
Post Posted: Thu May 02, 2013 4:12 pm
mnemonix wrote:
Both are 4.09.
haven't got one infront of me, but I worked my Maruti out to 4.11.
Regardless, I doubt .02 would make any difference.
Post Posted: Thu May 02, 2013 4:17 pm
1l is 4.11.
Post Posted: Thu May 02, 2013 4:19 pm
Jimny is 4.09 too? or Jimny is 4.11?
Post Posted: Thu May 02, 2013 4:33 pm
My maruti front and rear were both 45/11. Ie. 4.09.
Have since used jimny rears on 2 occasions, they were both the same ratio.
I must be the luckiest Bastard alive then?
Post Posted: Thu May 02, 2013 4:52 pm
4.09:1... i'd beleive the words that come out of this man's mouth. :wink:
joeblow wrote:
Benz2369 wrote:
i know the diff ratio on a auto Jimny is different to a manual one
yet to see an auto one that has a different ratio than a manual. i've contacted suzuki about different ratios for that model and they do not exist. they are all 4.09:1.
Post Posted: Fri May 03, 2013 3:32 pm
in all honesty i wouldnt know since i've never bothered counting either, I just remember reading an argument of someone claiming one was different to the other
Post Posted: Fri May 03, 2013 5:00 pm
4.09 or 4.3 avaliable.
Post Posted: Sat May 04, 2013 8:24 pm
^ your post makes no sense!
Post Posted: Sun May 05, 2013 7:59 am
mnemonix wrote:
Both are 4.09.
Bingo. It didn't bother mine at all. The difference is equivalent to airing the front tyres down less then the rear.
Post Posted: Sun May 05, 2013 8:58 am
kenn wrote:
mnemonix wrote:
Both are 4.09.
approx 0.49% different between 4.11 to 4.09
so 31" tyre *25.4mm*0.49% = 3.85mm diff in diam.
Heaps of 4x4s have way more wear difference front to back than this.
F-all difference.
Post Posted: Mon May 06, 2013 11:36 am
are matuti diffs 1300 or 1ltr size?
Post Posted: Mon May 06, 2013 3:31 pm
Ive got maruti diffs fitted to a wt diff housing. But there is nt and wt maruti's
Post Posted: Mon May 06, 2013 3:46 pm
both.
WT's are 1300 size, NT's are 1L size.
Post Posted: Mon May 06, 2013 6:39 pm
Thanks guys! the hunt continues!
my diff is ok for the moment. still nosey! but not so much!
want to try to get a GOOD c/p and build with a air locker.
Post Posted: Sun Sep 22, 2013 6:49 pm
digging up an old thread: so what was the consensus on maruti vs jimny ratio's? would a jimny crownwheel and pinion be suitable for a swap into a WT maruti rear to replace frucked C&P without having to change the front?
Post Posted: Sun Sep 22, 2013 7:37 pm
Yes, its how I run mine. Jimny rear is identical to maruti and can be put in front or rear.
Post Posted: Sun Sep 22, 2013 7:46 pm
the whole centre or just the C&P? and is it only the early G13bb jimny's or is it all? cheers for the help
Post Posted: Sun Sep 22, 2013 8:23 pm
Whole centre.
I haven't personally pulled a centre from anything newer than around '05 so can't comment on new models. All the old ones I have seen were OK to use.
