It is currently Wed Nov 04, 2026 11:17 am
Vehicle: Vitara
Post Posted: Mon May 27, 2013 12:10 am
hey guys, went for a drive around mt dissapointment (victoria) and i heard a loud noisy bang noise and then the front wheels dont spin, however i can still select 4wd high and low, and 4wd low still engages and works, just the front two wheels arent spinning and the hubs are locked. What could be the cause? I dont want to spend all day looking at the car and not pin pointing the problem. should i be looking at
-hubs
-transfer case
-gearbox
-driveshafts
-opening up the diff
Post Posted: Mon May 27, 2013 6:22 am
what I would check in order:
driveshaft (easy to look under car)
hubs
CV's
diff
t-case
MY BUILD THREAD HERE!!!!!
Post Posted: Mon May 27, 2013 7:32 am
Did it go noisy bang noise when your front wheels were spinning? Any other noises whilst moving ind 4wd? Being a vitara, the probability of it being the alloy front diff is high.
Vehicle: Vitara
Post Posted: Mon May 27, 2013 1:41 pm
I was trying to climb up this hill and then when bang, and it popped out of 4wd L and then I put it back in, awhile I realised I wasn't in 4x4.. But can still select the gears
Post Posted: Mon May 27, 2013 5:36 pm
:beer:
Post Posted: Mon May 27, 2013 6:31 pm
As above, I would suspect the front diff
then CVs
Did you end up welding the front diff or putting a locker in it?
Did you put a locker in the rear yet?
http://auszookers.com/forum/viewtopic.php?f=37&t=40307
Vehicle: Vitara
Post Posted: Mon May 27, 2013 9:01 pm
Figured and fixed the problem.
It was the front left wheel hub bearing, causing play in the hub, and the drive shaft circlip slipped out of the grove and the driveshaft was just spinning outside the hub.
Vehicle: Vitara
Post Posted: Mon May 27, 2013 9:02 pm
then CVs
Hadvnt had the time to look into it, been busy with work
Users browsing this forum: Google [Bot] and 99 guests
