It is currently Wed Nov 04, 2026 4:34 pm
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Sat May 25, 2013 10:48 am
Hey guys. i know this topic has been posted probably a thousand times but i cant find any info on leafy sierra shock swaps. ive heard of a few people putting commodore shocks in vitaras but not much info on sierras. my sierra rides so rough and today ive ripped the shocks out of it and gone for a test drive. i reakon driving it without shocks has fixed the harsh ride by 75%. I have rancho 5000 shocks in atm and they feel shagged. also i have 2 inch lifted leafs. I pushed the shocks all the way in and they dont even come back out or budge and wen you pull them back out by hand they are very notchy.
Wondering if any of you guys has experienced any of this crap with rancho shocks even if they are only 30 - 40,000 km old
cheers for any help and info guys.
Vehicle: WT sierra, GU CRD
Post Posted: Sat May 25, 2013 6:35 pm
Hi Rob I'll go out and read the part number later on my gabriels.
How many leaves you have in the lift springs?
Why did you get rancho's, dont they have a bad name for being way too stiff for our application?
Edit: Went out and read them and they aren't what others have
733518 on the back
733508 on the front
Couldn't find on the gabriel's site what they are off or anything about them so here's the longer shocks super happy thread.
viewtopic.php?f=37&t=34303&hilit=longer+shocks
I love ZD30. :)
Vehicle: Suzuki/Sierra/1988 SJ50 HiTop
Post Posted: Sun May 26, 2013 7:21 am
My SJ413 had a terrible ride when I got it (standard springs & bad choice of aftermarket shocks). I tried three different brands of shocks before I was happy with the ride (plus the original aftermarkets on the car when I bought it makes four sets!). I settled on Lovells Gas Legend.
Post Posted: Mon May 27, 2013 8:02 pm
Well i bought my car with the shocks n springs already in it. The old owner gave me a bunch of receipts withthe car and they are from a company called 4WD1. Springs are 2 inch lift 'rockcrawler' brand and the rancho 5000s but I've hated the rough jagged ride ever since I've owned it
Post Posted: Mon May 27, 2013 8:04 pm
Rancho's are rough. I reckon the Commdore/Hiace combo is too rough also. Probably because they're from a heavier car and coil spring valving.
Post Posted: Mon May 27, 2013 8:45 pm
I got a good ride out of the LJ80 with Commodore shocks*, they're a little stiffer than I would like but compared to the originals it feels much more controlled. I put new springs in at the same time though, 2 7.5mm leaves (might have been 7mm, can't remember) in the front spring packs and 2 7.5 a 6mm and the original load leafs in rear packs, all with slipper pads and spring spacers. That's in a LJ which is roughly 200kg lighter than a 1.3l Sierra.
The shocks are much, much stiffer than the originals. Hence my efforts to reduce spring friction. I'l look else where for my next shocks but these did what I want and were very cheap. Summit have a lot of cheap "brand name" shocks.
JrZook is running Koni 80 series shocks under his, he went to a fair bit of effort to get a good ride and he seems really happy with them.
*81340 Gabriels. Normally $49 each IIRC, I got mine for about $35 on special at supercheap. SWB LJ80s use pin-eye shocks back and front where as the Sierras just use them in the front.
Post Posted: Mon May 27, 2013 9:11 pm
733518 on the back
733508 on the front
http://auszookers.com/forum/viewtopic.p ... ger+shocks
I cross referenced those numbers and the rears are 81147 Gabriel's and the fronts are too long fully compressed
Post Posted: Mon May 27, 2013 9:20 pm
Not sure what you mean. The numbers in the thread or the ones off mine?
I love ZD30. :)
Post Posted: Mon May 27, 2013 9:24 pm
Numbers off yours
Post Posted: Mon May 27, 2013 9:57 pm
2stroker wrote:
I believe that these commodore shockies are a good cheap option however on standard length springs they are not as good as something like a 1971-1978 holden station wagon shock which is 297mm compressed and 497mm extended and is a lot better than a standard sierra shock at 256mm - 415mm.
Go into a super crap and ask for these then. They will be able to work out a part number for ya.
My shocks work fine even if they are too long.
I love ZD30. :)
Post Posted: Tue May 28, 2013 6:31 am
Sounds like a plan. Super cheap have a sale starting tomorrow. 25% off Gabriel shocks. Not sure if that's only in nsw though
Post Posted: Thu May 30, 2013 7:19 pm
Ok so here goes. This is the combination of shocks I've found that work with my leafy sierra with a 2 inch lift .
For the front Gabriel 81416 and they measure 294mm compressed and 472mm fully extended.
For the rear i used Gabriel 81147 and they measure 314mm compressed and 513mm fully extended.
Got them from supercheap auto and all up they cost me $142.64 on special.
Also note that these shocks are discontinued and may be hard to find so you may need to cross reference them.
Any help feel free to pm. Cheers !
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Jun 02, 2013 6:48 pm
Koni shocks are very good, there only single direction but great cos there adjustable.....In my opinion.
Post Posted: Sun Jun 02, 2013 6:55 pm
what is a single direction shock :?
don't all shocks have a compression & rebound stroke or am i missing something
Post Posted: Sun Jun 02, 2013 6:58 pm
I think Keensy means that Koni's are only adjustable in one direction. (Rebound)
Steve
Post Posted: Sun Jun 02, 2013 7:02 pm
clear as beer in a mud bottle
tried to Google for explaining facts but to much crap came up about 1 direction.
Pretty much when u compress them they dont exstend back out on there own ,aparently rancho adjustable shocks are the same so i hear :?:
Post Posted: Sun Jun 02, 2013 7:17 pm
:rofl: :rofl:
Post Posted: Sun Jun 02, 2013 7:19 pm
That doesn't mean anything Keensy, it just means they aren't high pressure gas shocks. Yes, Koni oil and Rancho's are the same in this regard.
HIgher has pressure can be an aid in preventing the shocks fading due to the oil foaming.
There are koni Gas shocks which will self extend, however, I don't recall if they are adjustable or not.
Rancho 9000's adjust both rebound and compression via adjusting the foot valve.
Koni's adjust only rebound.
Koni's are a very high quality shock, but any shock is only as good as its valving - a poorly valved shock will screw the ride and handling of a car up regardless of the quality of its construction.
Steve
Vehicle: Sierra Ute
Post Posted: Thu Aug 22, 2013 9:19 pm
I have a stock '85 Sierra Ute. I drive 60 k's a day over rough, potholed back roads. My 60+ year-old back is killing me. What shocks do you recommend for a soft ride, without too much cost, please?
Users browsing this forum: Google [Bot] and 257 guests
