It is currently Thu Nov 05, 2026 12:06 am
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
Vehicle: 95 Sierra
Post Posted: Tue May 28, 2013 9:08 pm
Hi All, I understand my plans will not be everyones cup of tea but I have joined up as I have just purchased my Sierra and would like to share my project and get some advice on my planned build up, try not to flame too hard. :-)
My Car: '95 Sierra, white, soft top.
My Plans: 12A Rotary conversion with 5 speed gearbox, rwd conversion, slightly lowered and drag wheels.
The build up I am going for: Puerto Rican Rotary drag style, as below;
http://www.2040cars.com/_content/cars/i ... 38/001.jpg
http://i222.photobucket.com/albums/dd32 ... CT0602.jpg
I will be doing every aspect of the work myself, I would just love some advice on a few of the core tasks:
Lowering kit: Whats out there? Whats good? I am after a height similar to the above red car.
Hub/Stud Conversion: I want to run Weld Pro Star wheels, the most common pdc is the usual 5x114.3, I have seen conversion/spacer plates for Sierras, is this suitable or is another method recommended?
Wheel Offset: Any idea how to achieve the stance as per the pics? I guess that ties in with my above question regard hub conversion.
Roof Bars/Roll Cages ?
Thats it so far :-) look forward to some advice.
Post Posted: Wed May 29, 2013 9:45 am
Rotary is about the worst engine for Sierra repowering.
Peaky, noisy and a bitch to fit. The trans tunnel needs to be raised A LOT.
NO lowering kit is available from anywhere for Sierras. You'll need custom reverse eye springs and possibly 4 X chassis notches.
NO hub conversion is available that I'm aware of. I'm sure WELD will drill wheelstud holes to F100 pattern with the amount of $$$ you'll be spending.
As a drag car you won't want the heavy front diff. What do you intend to use for a front axle?
Rear axle will need to be replaced with something stronger with a wider choice of ratios.. EG: Borg Warner from 2wd Hilux or even a 9".
Post Posted: Wed May 29, 2013 9:54 am
Samurai's came out in a 2wd over in the states. They retained a transfer case of sorts which I assume just lowered hi-range but didn't have any low range or 4wd outputs. If you could source a 2wd front axle you might find it very easy to install and you would be loosing a lot of weight over the front that is redundant.
Definitely need a bigger diff out the back if you start getting aggressive with the rotor. Can't see any pics to offer advice on wheel offset but if you change your diff you might find you need a different PCD front to back.
Vehicle: 85 ' Drover
Post Posted: Wed May 29, 2013 10:33 am
It sounds like you are trying to build a drag car that happends to look like a suzuki sierra. and not intersted at all in the 4wd capability of the sierra.
Given the fat that that the seirra has the aerdynamics of a shoe box, id start with something else.
Your better off with an old corolla or something and put your 12a in that, get a big diff and some sticky tyrs and it will be a rocket.
Vehicle: 95 Sierra
Post Posted: Wed May 29, 2013 12:41 pm
"Samurai's came out in a 2wd over in the states"... ahhhh ok makes sence, looks like I will be attempting to track down a front axle. thanks for the tip ;)
Rotary is not negotiable. (I run a small shop dedicated to rotary performance.) The car will be based around drag yes but also very much streetable.
"start with something else" nope, I already have a host of other fast cars, the Suzuki is going to cop it.
The car will start off as a 'stage 1' which with take a standard(ish) low powered 12A to get the conversion happening. it then may develop into something a little more powerful.
I might have to jump on the PR forums to see how they are lowering them, I imagine it is not a popular task here, we are more set on raising them (which is cool too, hey I loving going out bush with some dirtbikes).
The HUB conversion was these spacers I saw on ebay which converts the 5.5" to a 4.5" pdc. I think this may be a good option to get the right stance too.
http://www.ebay.com.au/itm/281107560731 ... 1423.l2649
Post Posted: Wed May 29, 2013 1:36 pm
Where are you located?
Vehicle: 95 Sierra
Post Posted: Wed May 29, 2013 2:35 pm
Nice to see another rotor head !
Sydney mate.
Post Posted: Wed May 29, 2013 3:40 pm
There are heaps of rotary powered Sierra drag cars, which seem to put down fast times... Lightweight & a full chassis to build a 4 link rear end off. Sounds like a winning combo to me & the puertoricians would agree.
Post Posted: Wed May 29, 2013 4:34 pm
Lowering blocks and big track bar.
Post Posted: Wed May 29, 2013 4:40 pm
Like a 4link haha.
Post Posted: Wed May 29, 2013 4:44 pm
Like a 4link haha.
nah, just 4 small track bars & no leaf springs. :lol:
Post Posted: Wed May 29, 2013 4:58 pm
Sounds like it'll be a kick ass sierra good luck with it matey.... What are you doing to the engine??? Big ported turbo??? Keen to see this going ahead good luck with it all champ...
Post Posted: Wed May 29, 2013 6:18 pm
Why not keep it 4wd for better offline grip?
Vehicle: Getting parts atm
Post Posted: Wed May 29, 2013 6:54 pm
Body drop it
Vehicle: 95 Sierra
Post Posted: Wed May 29, 2013 7:08 pm
first step will be getting a 12A in there...... 12A with intake, exhaust, simple modified carby and slight port work can put out some decent power - I can do all this work myself with very little cost.. it will get a little light Sierra moving.
Keeping 4x4 was a consideration but I think I am going to go the direction of Weld wheels, big burnout at the drags, will generate a bit of attention and be good for my business, but most important a fun ride.
I am going to really enjoy this build up.
Body Drop, Lowering Blocks? give me some more details.... :) suppliers, methods..
Post Posted: Wed May 29, 2013 7:14 pm
body dropping is channeling the floor/body mounts to drop the body lower over the chassis = extra lowness 8)
Post Posted: Thu May 30, 2013 10:04 am
Sydney mate.
:D :thefinger:
Uploaded with ImageShack.us
Vehicle: 95 Sierra
Post Posted: Thu May 30, 2013 10:11 am
f**k yeah ! Thats what i like to see :D :D
I actually stumbled across your thread briefly on rx7club last night whilst searching for Sierra Rotors, I understand you are still running 4x4.
details details, do you have a build thread? would love to chat sometime for some ideas......
BTW: Does anyone have any further ideas on a front axle for RWD conversion?
Vehicle: 95 Sierra
Post Posted: Thu May 30, 2013 10:18 am
good taste too !
Series 1 - 13BT, TO4.
Sierra - Soon to have an engine bay like yours.
Post Posted: Thu May 30, 2013 10:34 am
Nice rx and zook!
Mines a S3 13BT hi-flow, 340Hp. 11.4/quarter mile.
I don't have a build thread just yet as I didn't want a flame war until I got it running....will put one up eventually.
I'm still running 4wd and stock ride height...I too was gonna lower it like the green/blue zook's in the 2nd pic, as I love that pic too, but it wasn't really what I want the car for...I want to use the Zook to get down on the beaches etc.
Car is still in pieces at the moment....the above pic was just a test fit for clearances etc.
Cam...
Post Posted: Thu May 30, 2013 11:04 am
What more do you need other than a bolt in alternative? :?
Post Posted: Thu May 30, 2013 11:12 am
just remove the diff centre tail shaft and axles from the front diff.
there rest weighs next to nothing
Post Posted: Thu May 30, 2013 11:38 am
Get joe to graft sierra balls on to a straight pipe
Cut down a vit rear and full float kit like g wagons post
Or sell it and buy a vit they already have everything ready to go
Rip out front diff throw a spool and floater kit in back and put watever motor u want in it
Post Posted: Thu May 30, 2013 11:59 am
Why does Joe need to do it? :lol:
Post Posted: Thu May 30, 2013 12:04 pm
Thats exactly how I was thinking about doing it.. well except for joe doing it.
Probably not use a xfer case either (which would dictate if you need a centre or offset diff pumpkin)
Raise rear floor, and notch the chassis rails, set up the suspension so it runs heaps lower.
You could just run lowering blocks between leaves and axles after notching chassis.
Add a trac bar.
Post Posted: Thu May 30, 2013 1:02 pm
Add a trac bar.
Deffo need a traction bar after this! The extra amount of leverage from the blocks will be no fun for the leafs. Reverse wrapped springs would be a welcome addition.
Vehicle: 95 Sierra
Post Posted: Thu May 30, 2013 3:17 pm
Not having much luck finding one, plus the cost and time to come from the US far out weighs a local option.
sounds simple, any downside to this method?
Joe?
Vehicle: 95 Sierra
Post Posted: Thu May 30, 2013 3:19 pm
JrZook wrote:
Add a trac bar.
thanks!
the help has been great so far. car is just going through a tidy up at the moment and replacing worn oem bits, etc.
Post Posted: Thu May 30, 2013 8:19 pm
Means pumpkin may hit stuff. Will be easier to lower it if doesnt have the pumpkin
Joe?
Joe is a person in melb, Im certain it could be done locally
Post Posted: Thu May 30, 2013 8:28 pm
Shave the housings top and bottom HEAPS haha.
Users browsing this forum: Google [Bot] and 230 guests
