It is currently Wed Nov 04, 2026 4:34 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Vehicle: 1995 soft top vitara
Post Posted: Wed Jun 12, 2013 2:23 pm
hey guys,
i am looking into lifting my swb vitara up and i dont really know what kit to buy or put together? my car has a little bit more weight up front then stock and is also fitted with a arb winch bar
my current options
-calmini 3"kit, i have read they arent great due to the poor quality of springs shocks and struts $1400
-lror 2.5 kit, havent read up on it to much still $1300
-dobinson 40-50mm kit from dank, most people running this kit are using different spacers and shocks etc $850 plus
-put together a kit using springs and shocks from different model cars?
what are you running in your vitara?
though your experience what works best, best bang for buck also?
i plan on doing gaurd trimming to fit 31s, i dont want to bodylift the car as i would have to replace intercooler piping cahange wiring etc.
any help would be great
Vehicle: sj70 sierra
Post Posted: Thu Jun 13, 2013 9:18 am
recently bought my vitara and this is what the previous owner said he has done. im new to 4wding and this is the only 4wd ive driven so my opinion probably isnt great but it seems to flex really well and i have heaps of clearance
3" Full Calmini Suspension
Dobinson front struts,
Toyota 80 series rear shocks for extra flex ( added nearly 2 inches in the rear)
flex pic:
how it sits normally
Vehicle: 95 Vitara Hardtop
Post Posted: Thu Jun 13, 2013 10:47 am
I have recently fitted the standard Dobinsons 40mm kit from Dank, and it made a good difference. Ride on the road is a bit firmer but well controlled, currently running the front sway bar disconnected for better front suspension performance off road, does give a bit more body roll on road but it was very tight with the sway bar still connected.
Off road the car performs better in a variety of situations, with the diff height now being the limiting factor.
Vehicle: Black '96 X-90
Post Posted: Thu Jun 13, 2013 11:01 am
In the front I've got a pair of Tough Dog 40mm springs, Swaybar removed, with an ARB bar on. Standard pedders struts.
Rear I have Nissan 180sx springs and Tough Dog 40mm "Nitro gas shocks".
Nanakang FT-9 30's, No guard trimming.
Everything else I think is standard.
At full flex the rear tyres chew on the mudflaps.
I had a pair of TD springs in the back but they were too firm.
Post Posted: Thu Jun 13, 2013 11:24 am
altered ego
Post Posted: Thu Jun 13, 2013 12:19 pm
Or try the calmini strut elminator
With xl7 front coils instead of the vit ones
Rear ur on ur own
Post Posted: Thu Jun 13, 2013 2:39 pm
altered ego
you still :deadhorse: ? :lol:
Post Posted: Thu Jun 13, 2013 3:05 pm
Someone has to give it a go. 8)
Post Posted: Thu Jun 13, 2013 6:30 pm
Thanks for the replyies, still dont know what way to go.
hey tom240, your vitara tooks pretty tough. i would love for mine to be around that hieght. Have you got camber bolts fitted? any spacers?
Post Posted: Thu Jun 13, 2013 6:42 pm
thanks.
camber bolts on the front, hence the positive camber. coming from owning a silivia, when you say spacers i instantly think of wheel spacers, but i think you are talking about suspension? front shocks have spacers, not sure about the rear. can get a better look for you if you want?
Post Posted: Thu Jun 13, 2013 7:30 pm
Yeah i was reffering to strut and spring spacers haha
Post Posted: Thu Jun 13, 2013 7:33 pm
if it's the full calmini kit unmodified it would have the strut top spacers in the front & looking at the flex shot there is no rear coil spacer & it sits pretty level so i'm guessing there is no coil spacer in the front.
Post Posted: Thu Jun 13, 2013 7:49 pm
sick profile pic almost looks as good as mine^
Post Posted: Thu Jun 13, 2013 7:51 pm
Nice avatar :thefinger:
Post Posted: Thu Jun 13, 2013 7:52 pm
it's a beauty, the clearance lights on the front make it look like a truck. Armsup
Post Posted: Thu Jun 13, 2013 7:55 pm
hahaha mate you need to grow up one day what are you, like 40? get over your self
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Thu Jun 13, 2013 8:53 pm
[/quote]
thanks.
camber bolts on the front, hence the positive camber. coming from owning a silivia, when you say spacers i instantly think of wheel spacers, but i think you are talking about suspension? front shocks have spacers, not sure about the rear. can get a better look for you if you want?[/quote]
Do you mean you needed camber bolts because you had positive camber or you used the bolts to get positive camber?
Post Posted: Thu Jun 13, 2013 8:56 pm
its got positive camber because of camber bolts. i didn't set it up like that, new to 4wding so im not sure thats good or not? guessing a bit of positive camber is good because then when the downhill wheel is flexed up it will be at a better angle to keep grip?
Post Posted: Thu Jun 13, 2013 9:01 pm
With the Vitara front end, as you lift it, the front wheels tuck under.
as theres no adjustment built in,
adding camber bolts helps puts the wheels back to stock spot, or more if wanted.
Can be a bitch to steer at speed with the wheels tucking under.
Post Posted: Thu Jun 13, 2013 9:02 pm
you wan't zero or negative camber, you sure you're not getting your + & - mixed up?
when looking at the front of the car
positive looks like this \ /
negative looks like this / \
the camber bolts should have been fitted to achieve neg camber.
have a suss of this thread viewtopic.php?f=17&t=23387&hilit=camber
Post Posted: Thu Jun 13, 2013 9:07 pm
I learn summit every day. Always though + was bottom of wheels stickin out
Post Posted: Thu Jun 13, 2013 9:15 pm
successful thread hijack was successful. :oops:
Post Posted: Thu Jun 13, 2013 9:25 pm
Oops
back on track, these might help you decide what you need to do for 31s
dont forget to consider the effect on gearing, especially the already not so low low 1st in you vitara
viewtopic.php?f=5&t=27564
viewtopic.php?f=5&t=41155&p=746908&hilit=fit+31+vitara#p746908
Post Posted: Fri Jun 14, 2013 3:21 pm
i already run 30" tyres, power is not a problem at all for my setup lol.
eventually i would like to run 31"-32" mud tyres.
basically i need to decide on what lift to get which is giving me a headache at the moment hahaha
Post Posted: Sat Jun 15, 2013 9:47 pm
Power isn't the same as gearing. You can have all the power in the world and still have terrible gearing.
Just my 2C.
Vehicle: vitara
Post Posted: Sat Jun 15, 2013 10:05 pm
ok. ive spent abit of time looking onto this myself... I only just fitted a lift to my vitara last week.
to start with in NSW you can legally go 2" lift without having to get engineer report thingy.
this is the option I chose, and the reason why. I looked into alot of kits. long story short is
ironman leaks as has alot of bad reviews. tough dogs 2"kit is actually only 30mm. and alot of the rest
are far to experience and non are better then dobinson (but get the long wheel base kit) that way you can
carry more then 3 marshmallows without droping back down.
with this kit (not yet tested but hope to by the end of the week) you should be able
to get 30" muddys on which would bring your ride high up enough to challenge
most. some guys will disagree and say bigger is better but if you learn to drive and pick
the right lines then no dramas.
if you wanna tuff truck then thats another matter all together.
well this is my opinion but remember its your car.
p.s. full 2" dobinson kit is less then $1k with camba bolts. in sydney talk to
brad. tell him Dan from Toyota put you on and see if he cuts you a deal... he should
do. hes a good lad.
Vehicle: 90 Vitara
Post Posted: Mon Jun 17, 2013 2:48 pm
I've been watching the Iron man sets on eBay for like $780
Then maybe some shock spacers at the front n spring spacers on rear if i need more than 3in
Post Posted: Mon Jun 17, 2013 5:34 pm
from perth with free delivery?
i just got one and will be fitting it this weekend,
FYI if you arent home when they first deliver then you have to go to the depot to pick it up, so make sure you have an authority to leave made out toll ipec if you dont have someone to sign for it.
I know lots of people dont like iron man but i have run their coils on the front of my old Jeep XJ for over 20,000km including a trip to via flinders and Oodnadatta and on my forester and cant complain, this will be my first time using their shocks though.
Post Posted: Mon Jun 17, 2013 5:47 pm
Can you get away with some 2" coilpacers with no other mods?
Post Posted: Mon Jun 17, 2013 5:52 pm
would still need to do something about the shocks/struts.
Users browsing this forum: Google [Bot] and 252 guests
