It is currently Wed Nov 04, 2026 6:41 am
Vehicle: 2inch lift extractors ext
Post Posted: Mon Jun 17, 2013 5:36 pm
Hello fellow zookers I am the owner of a Lwb 96 model vitara with a 3 inch calmini lift kit and 2 inch body I am currently running 16 inch rims with mud claw tyres I am wanting to step it down too 15 inch sunrayser style rims could some one please tell me the best off set to run? As the tyre store is telling me I can only run 16s as 15s will hit the caliper.
Cheers James
Post Posted: Mon Jun 17, 2013 5:45 pm
calmini have specific instructions on what offset to run, but list it as a backspacing measurement.
from memory it works out to something like -15 in a 15x7 & you won't need 16's unless you're running the V6 vitara brakes.
EDIT: here is a pdf of their backspacing babble. http://www.calmini.com/docs/bulletin-su ... laimer.pdf
DOUBLE EDIT: here is a thread with heaps of different rims & their offsets + another one on how to convert backspacing to offset. http://auszookers.com/forum/viewtopic.p ... edy+offset
http://www.speedywheels.com.au/wheel-tech.htm
Post Posted: Mon Jun 17, 2013 5:56 pm
Cheers Atari :)
Post Posted: Mon Jun 17, 2013 6:12 pm
Thanks Atari I already had 2 sets of steel rims the problem I am Gavin is that there running on the calipers and I am trying to find out what brand an offset people are using
Post Posted: Mon Jun 17, 2013 6:14 pm
and what offset are they? :?
i run & recommend the speedy desert rat 15x7's in a -15
Post Posted: Mon Jun 17, 2013 6:20 pm
And do they clear calipers ok? And would they stick out a lot? Cheers
Post Posted: Mon Jun 17, 2013 6:27 pm
they should do, heap of people run smaller offsets with no problems. they only just hit on the big brakes of the V6 vitara before a lick with the grinder... what offset are the rims you're having problems with?
yeah they'll stick out alot, they have to so the springs work properly as per calmini's specs.
Post Posted: Mon Jun 17, 2013 6:47 pm
Not sure of the offset I am workin with at the moment but they fit my short wheel base with not hitting but don't fit my wagon
Post Posted: Mon Jun 17, 2013 6:50 pm
LWB brakes are bigger than the SWB's & the 2.0l vitara's are bigger again, they must be a big + offset to be causing issues.
they're not the rims fitted to your blue SWB in the forsale ad?
Post Posted: Mon Jun 17, 2013 7:04 pm
Nah there different rims to the ones in my add man
Post Posted: Mon Jun 17, 2013 7:36 pm
I've jsut ordered sunnies in a 16 x 7 with a -13 offest ... putting 235 /75's BFG Muddies on them .... going -13 will give the same backspace as the std wheel
Users browsing this forum: No registered users and 178 guests
