It is currently Tue Nov 03, 2026 9:57 pm
Vehicle: Drover pickup turk
Post Posted: Mon Jun 17, 2013 8:01 pm
This one looks pretty munted.
I like the tuna here
Post Posted: Mon Jun 17, 2013 8:17 pm
Eh. New one couldn't hurt. But i'd use it if i had to.
Post Posted: Mon Jun 17, 2013 8:36 pm
X2. Bolt it in upside down if you have to use it - it will help. They always wear on the bottom more than the top.
Post Posted: Mon Jun 17, 2013 9:12 pm
Its like that the whole way around. Had to give it a few good hits because the bearing was stuck on.
Post Posted: Mon Jun 17, 2013 9:19 pm
that is rooted , not only is it pitted and worn where the bearing runs its pitted where the seal runs , so not only will you still have bearing play with a new bearing , you will still let moisture in to root that bearing.
i would replace it.
Post Posted: Mon Jun 17, 2013 9:25 pm
don't get me wrong, I'd replace it too, but sometimes you don't have a spare sitting around, and not everyone expects to get 100,000km out of a bearing before they look at it again.
If its not a daily, and you know it's less than ideal, I'd run it - I'd flip it upside down and make sure everything else is to spec. The fact the bearing was stuck on is a VERY good sign. the bigger problem with spindles is that they corrode/wear and the bearing goes loose and slips. ( I used to have this problem with the Gwagen) if the bearing was tight on the spindle, then the spindle is sound, it's only as big a problem as the seal surface.
In short, there's the ideal world, and the real world. Ideal - it would all be new. Real world - I'd run it, but I'd keep a keen eye on it.
Post Posted: Mon Jun 17, 2013 10:11 pm
Let me ask the question - the bearing doesn't run on that surface. the inner race slides over it, so as long as it's tight, the pitting is not an issue - the pitting in the seal area (which I suspect can be fixed by machining it down and press fitting a sleeve over it) is where the problem lies.
Is this what Steve is saying (apart from fixing the seal area)?
Post Posted: Mon Jun 17, 2013 10:26 pm
Yes. If the race isn't spinning on the spindle, it's all good.
Steve
Post Posted: Tue Jun 18, 2013 5:54 pm
Loos heaps better then one I pulled off mine... I'd run that though its only minor pitting... Next time you change your bearings get a new one
Post Posted: Tue Jun 18, 2013 6:21 pm
Hmm alright, Might get another one, Simply because its for my floater build + my car is a daily.
Users browsing this forum: No registered users and 102 guests
