It is currently Tue Nov 03, 2026 9:01 pm
Vehicle: Suzuki Grand Vitara
Post Posted: Tue Jun 18, 2013 10:53 pm
Tried to get the body lift in tonight but ran into problems,
I followed the instructions except the part where it talks about disconnecting the steering column to use extended bolts, however my 1 inch kit doesn't have them so I just left steering connected , everything else like brake lines and air intake were loosened off.
I started by lifting the drivers side and found that I could only just get the pins flush with the mounts before the drivers wheel started to lift off the ground, when it started to lift I checked all the lines and even though they were getting close to being tight, no where tight enough to lift the drivers wheel.
Has anyone done this on the GV and have any tips ? Anyone else thinks its the steering ?
Post Posted: Tue Jun 18, 2013 10:57 pm
Did you disconnect the brake lines on the inside of the frame rail?
Post Posted: Tue Jun 18, 2013 10:58 pm
steering
Post Posted: Wed Jun 19, 2013 7:10 am
Steering. It needs to be disconnected, even though you don't need a spacer once it goes back together.
Post Posted: Wed Jun 19, 2013 10:12 am
fordem, yeah mate i disconnected all the lines from the chassis
atari4x4... gwagonsteve..... thanks i figured it would be the case but was hoping to get away with not having to disconnect the steering as i did a mates v6 vitara with him the week before and didnt need to....
Will have another crack at it this weekend
Post Posted: Wed Jun 19, 2013 10:29 am
just one more question, am i better to undo the two bolts of the bracket peice which holds the two shafts together, slip it down to seperate, or undo the bolts at the joint further down?
Post Posted: Wed Jun 19, 2013 10:30 am
either or. the rag joint will probably be easier
Post Posted: Wed Jun 19, 2013 11:10 am
on the vitara's i undo the clamps on the uni joints where they bolt to the splined section & then after the lift re-centre the shaft on the splines, not 100% familiar with the rack & peanut set up on the GV
Post Posted: Wed Jun 19, 2013 6:43 pm
yeah i unbolted that clamp last night, but couldnt get it to budge, il try a bit of crc and see if i can get it to slide down
Post Posted: Wed Jun 19, 2013 6:46 pm
might need a bit of gentle loving from a soft blow hammer.
Post Posted: Wed Jun 19, 2013 8:11 pm
You'll have to take the bolts right out, and then reassemble once the BL is in.
If your GV has an airbag or steering wheel mounted controls, make sure you lock the steering lock before you disconnect, or you could (will) stuff the clockspring.
Post Posted: Thu Jun 20, 2013 4:47 pm
Thanks Steve, sorry I have to ask....what's the clock spring and do u think I would have damaged jacking it up without disconnecting already ?
Mine does have airbag
Post Posted: Thu Jun 20, 2013 4:54 pm
googled steering wheel clock spring = http://en.wikipedia.org/wiki/Clockspring
can you also start quoting under people so it reads like a normal converstion. :deadhorse:
Users browsing this forum: No registered users and 69 guests
