It is currently Wed Nov 04, 2026 6:02 am
Post Posted: Tue Jul 23, 2013 10:01 pm
bought a digital volt gauge off ebay thinking it would be a walk in the park install. went to install it and then hit a wall of confusion. it has two wires red and black. obviously for positive and negative.. but! I don't want it running all the time, only when the car is on access or actually on.. so how the heck do I wire it up!?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Jul 23, 2013 10:03 pm
back of the cigerete lighter
Post Posted: Tue Jul 23, 2013 10:06 pm
and still give me the correct volts of what the battery is sitting at when the car is off and then when car Is running ?
thanks for the quick as hell reply!
Post Posted: Tue Jul 23, 2013 10:07 pm
what do the instructions tell you to do? :?
Post Posted: Tue Jul 23, 2013 10:16 pm
it was from some sweatshop in god only knows where and I purchased through ebay, you think it came with instructions? haha
Post Posted: Tue Jul 23, 2013 10:18 pm
post a link to the ebay ad
Post Posted: Tue Jul 23, 2013 10:24 pm
it would be long gone now from my ebay list haha and it was much easier to ask here and get a response in 10 seconds from people I am lead to believe will give me the right information rather than scrounging around other foreign forums :D
Post Posted: Tue Jul 23, 2013 10:27 pm
Just wire it to the battery via a switch
Post Posted: Tue Jul 23, 2013 10:28 pm
that would mean having to flick I switch all the time.. would wiring it to the cig lighter give me a ' as accurate ; reading as direct to battery ?
Post Posted: Tue Jul 23, 2013 10:29 pm
so you essentially want us to spoon feed you? :roll:
with the info you've given, you'll be hard pressed to get shit... post pics of the box, the unit & where the wires come from. are there any markings where the wires come out of?
Post Posted: Tue Jul 23, 2013 10:33 pm
not entirely.. just a straight up experienced answer. so that I can then try it, see it works and then help someone else if it ever arises again. :) Armsup
and it quite literally Is a display.. connected to a chip board with two wires hanging off it.. haha
Post Posted: Tue Jul 23, 2013 10:38 pm
:oops: i'll crawl back in my box, i miss read the first post saying it had 2 red wires & a black... but if it's only got a red & black. the first answer was correct, it's on switched power... will turn on with acc power & give you a read out of battery voltage. :wink:
sorry chief :oops:
Post Posted: Tue Jul 23, 2013 10:42 pm
nar dude,all good! I'm not intentionally trying to be a pain in the arse haha :D it just seems better to ask all questions here regardless of nature as this is the Suzuki info hub and don't wanna get caught out not knowing something exclusive to Suzuki's and not other cars!
Post Posted: Wed Jul 24, 2013 1:26 am
Mine is just on my acc circuit
Vehicle: Coily.
Post Posted: Wed Jul 24, 2013 8:48 am
Ebay has one that plugs into the cigar lighter,just take it out when not needed.We purchased some and my brother compared them to a testing gauge and their reasonably accurate,they certainly drop fast when there is a drain on the battery so cheap & easy fix.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jul 24, 2013 1:03 pm
wiring to the cig lighter is the best bet. the only way it would be drastically inaccurate is if your drawing a lot of current through the stock wiring .eg youll see a drop in volts as a car fridge clicks on, and while the compressor is runing the voltage may be measured at slightly less than actual.
Users browsing this forum: No registered users and 184 guests
