It is currently Fri Oct 30, 2026 12:09 am
Post Posted: Fri Jul 31, 2009 12:22 am
I've seen somwhere people just cutting out there sills and replacing it with RHS. Im keen to cut stuff up and stick it back together but how strong would it be? If i dropped onto a rock would it push up into the door? I wanted to do this from the start but now my truck failed blue slip because of rust in there im happy to do it now...
Vehicle: 75 Cruiser
Post Posted: Fri Jul 31, 2009 12:32 am
here's mine... very strong :)
Post Posted: Fri Jul 31, 2009 12:36 am
vewy profishinal! :D
Post Posted: Fri Jul 31, 2009 12:44 am
Ok thanks steve did you brace it back from the chassis or did you just fully weld it in... i might see if i can find some silo rhs...
Post Posted: Fri Jul 31, 2009 12:50 am
ireckon this is the way to do it mate,if i ever take the time to redo things on my truck this will be one of the things to change.Should be reasonably strong.What else did you fail on???
Steves has come up great.I alsao remember bubs i think off OL doing some out of 75 or 100mm rhs a few years back.
Vehicle: 75 Cruiser
it's welded to the body along the top side of the box, and welded to the three cross braces under the body floor. I've dropped on to them heaps of times and no dents or cracking. So it's part of the body really.
PS. also is better than sliders because you have heaps of clearence.
Post Posted: Fri Jul 31, 2009 12:53 am
wouldnt running it back to your chassis aswell create a problem with cracking etc??you would have to either body mount it or chassis mount it
Post Posted: Fri Jul 31, 2009 1:16 am
fair enough app, thats a good point. I also failed on my PVC valve being cloged with grease... do'h and my wind screen wipers not working. I knew it wasn't going to pass but i just wanted to know what else needed fixing. Thanks for that steve ill get some RHS during this week, BTW what size did you use?
Vehicle: 75 Cruiser
Post Posted: Fri Jul 31, 2009 10:29 am
I can't remember the size and i'm at work now... it might be 40mm x 80mm box. It's definatley not 100mm x 50mm.
Post Posted: Fri Jul 31, 2009 10:55 am
ok cheers
Vehicle: 75 Cruiser
Post Posted: Fri Jul 31, 2009 11:16 am
or have a look at zukchiks sills...
http://auszookers.com/index.php?name=Forums&file=viewtopic&t=239&start=405
Post Posted: Mon Sep 06, 2010 5:30 am
Has anyone got more pics of stuff like this
Post Posted: Mon Sep 06, 2010 8:05 am
haha, nope, but i've mashed up my sill's so pretty soon ill be doing this...
Post Posted: Mon Sep 06, 2010 9:35 am
Mine. I used 3mm angle and spacers between the slider and the top of the kick panel. They have worked well however they bend fairly easily at the outer edge when dropped and slid along rocks so they will be replaced with 5-6mm angle soon. Not sure how road legal they would be.
Post Posted: Mon Sep 06, 2010 9:47 am
Red89 wrote:
Mine. I used 3mm angle and spacers between the slider and the top of the kick panel. Not sure how road legal they would be.
Legally they would be fine.
But 3mm is WAY too light.
The 6mm upgrade is a great idea!!
Post Posted: Mon Sep 06, 2010 9:48 am
I can't see your pic's.. :?
Post Posted: Mon Sep 06, 2010 9:53 am
nice pics noob :wink:
Post Posted: Mon Sep 06, 2010 10:15 am
Yer, was a rush job before last years comp and was all my brother in law had in stock.
Users browsing this forum: Google [Bot] and 139 guests
