It is currently Wed Nov 04, 2026 12:10 am
Vehicle: Suzuki
Post Posted: Fri Aug 02, 2013 10:57 am
I have 1.6 carby vitara, it had the little bit of blow by not to much but all of a sudden I have oil pouring out of tappet cover into carby via the hose. What has caused this need help
Vehicle: Suzuki
Post Posted: Fri Aug 02, 2013 10:59 am
It had rebuild by previous owner 40k ago as well and never used a drop of oil then this morning is have noticed massive amounts of oil running through that pipe into the carby causing it not to run
Vehicle: SJ70 1993
Post Posted: Fri Aug 02, 2013 11:32 am
i had same problem with my old g13ba and think we put it down to our fault for putting the rings in wrong and caused the blowby to pressurize the sump pumping more oil into the tappet cover and then along that pipe into the carby.
i maybe wrong as i never fixed it cause i put a g16b in it instead
Vehicle: 85 ' Drover
Post Posted: Fri Aug 02, 2013 11:46 am
Do a dry compression test, then a wet compression test.
That should give you a good indication if its ring related or valve stem related.
Vehicle: 1992 Suzuki Sierra
Post Posted: Fri Aug 02, 2013 1:28 pm
Have you checked the Pcv valve?
Vehicle: Suzuki
Post Posted: Sat Aug 03, 2013 8:42 am
What is a pcv valve and my oil level on dipstick has doubled and no water hasn't gone into it
Vehicle: Suzuki
Post Posted: Sat Aug 03, 2013 10:49 am
Just figured the problem out. Fuel pump diaphragm died causing motor to be filled with fuel
Vehicle: Daisy
Post Posted: Sun Aug 04, 2013 2:07 pm
Ouch, good thing that was found before it caught fire!
Users browsing this forum: No registered users and 88 guests
