It is currently Tue Nov 03, 2026 7:07 pm
Vehicle: Suzuki
Post Posted: Sat Aug 10, 2013 7:18 pm
Hi my vitara runs extremely rough until running temp, its a recent problem and was wondering if it is a choke stuck on something and how can I just block it off or something. (don't have any knowledge of carbys so need help)
Vehicle: sj70 sierra
Post Posted: Sat Aug 10, 2013 8:48 pm
g16a has an auto choke and yours probably isn't working. (neither is mine) Take off the airbox and have a look at the top of the carb, the plate with the red oval below is the choke, when its closed choke is on. When the engine is cold it should be closed and as the engine heats up it should open. mine was just staying closed so i just ziptied it open to save fuel economy. i would guess that yours is stuck open
Vehicle: Suzuki
Post Posted: Sat Aug 10, 2013 10:08 pm
Thanks I'll be checking it in the morning. I find it very weird though as until running temp it will blow smoke and run rough like its on 3 cyl and won't Idle then as soon as its at temp it's perfect
Post Posted: Sun Aug 11, 2013 6:28 am
Ah ok, sounds like your problem may not be the choke then
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Sun Aug 11, 2013 7:38 am
mine runs rough for the first couple on mins on cold mornings, it feels like it mas too much choke.
only happens on cold winter mornings and its ok by the time i get to the end of my steet
edit.i am going to replace the pcv soon and see if that helps
Vehicle: Suzuki
Post Posted: Sun Aug 11, 2013 8:19 am
Just tried playing with choke and that isn't it thanks anyway, what is a pcv?
Post Posted: Sun Aug 11, 2013 6:44 pm
http://en.wikipedia.org/wiki/Crankcase_ventilation_system
Users browsing this forum: No registered users and 447 guests
