It is currently Wed Nov 04, 2026 2:24 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
Vehicle: 2000 Jimny
Post Posted: Sat Aug 10, 2013 7:57 pm
Good guess Atari. Has a Rhino alarm fitted. Siren box is switched off but everything else works. Am thinking about getting a new one put in as that will enable me to sort and clean up some of the wiring.
Post Posted: Tue Aug 13, 2013 7:57 pm
Interesting....
Anyone like to hazard a guess if this would also work to correct a tacho signal? The tacho is currently run by a 'W' terminal (phase) on the alternator, and due to changing pulleys and alternators, now reads somewhat higher than the engine is actually doing. This is on a Range Rover.
Vehicle: 2000 Jimny
Post Posted: Tue Aug 13, 2013 8:02 pm
Depends on the signal input voltage and if it is linear
Post Posted: Tue Aug 13, 2013 8:13 pm
from my understanding, the w terminal is just linked to one of the phase's of the alternator....
Vehicle: 2000 Jimny
Post Posted: Tue Aug 13, 2013 8:20 pm
You will have to find out the signal voltage and if it is a linear signal. Or check if there is a tap off the ECU for a tacho
Post Posted: Tue Aug 13, 2013 8:37 pm
not sure what you mean by linear signal. The ECU picks up its engine rpm signal via the coil as a normal tacho would. The ECU is basically a Lucas made copy of the old Bosch L-Jetronic (flapper AFM) system. The setup with the tacho running of the alternator is factory Rover, just the alternator drive ratio has been changed.
Or maybe just machine up a new alternator pulley of the appropriate size would just be an easier way around it.....
Vehicle: 2000 Jimny
Post Posted: Tue Aug 13, 2013 9:08 pm
The Jaycar kit won't work off variable voltage signal (curve). It has to be linear (straigt) similar to a fuel gauge sender if you know what I mean
Post Posted: Tue Aug 13, 2013 9:37 pm
ah yeah.....ok. Ta
Post Posted: Tue Aug 13, 2013 10:24 pm
Maybe I'm missing something - as far as I know the jaycar kit is digital and counts pulses - it won't work off a variable voltage either linear or curved - I see no reason why it can't work off of an alternator output provided the signal is suitable conditioned - the output of a single phase from an alternator is going to be a sine wave with the frequency varying with rpm, you'll need to use some sort of a comparator to change that to a rectangular pulse - theoretically not very difficult.
There's also a possibility that you could "out run" the Jaycar kit since the alternator output is going to be running significantly faster than the speedo drive it's designed to work with.
Post Posted: Wed Aug 14, 2013 5:33 pm
Cheers.
a correctly sized alternator pulley sounds like it may be the better approach...
Users browsing this forum: Google [Bot] and 80 guests
