It is currently Wed Nov 04, 2026 2:23 am
Vehicle: 1989 jx tin top
Post Posted: Wed Aug 14, 2013 6:32 pm
So i got a newer gearbox for me zook... and i was wondering my old gear box only had 3 wires coming off it the new one has four?? (the one where im holding four wires.. the one with the circular head) does any body know what its for? Do i need it?
Vehicle: '94 suzuki maruti
Post Posted: Wed Aug 14, 2013 10:05 pm
i cant help by looking at the plugs but I'm trying to make sense of the FSM wiring diagram here. cant tell what the hell one colour means, it's code is Lg but doesnt state what it represents anywhere...
Reverse - 1 yellow, 1 red wire
Neutral - one black wire plus Lg/yellow stripe
5th switch - black/white stripe, Lg/red stripe
4th switch - exactly the same as 5th, probably what was missing from your old box as not all models had that
Post Posted: Wed Aug 14, 2013 10:13 pm
Lg = Light Green :wink:
Post Posted: Wed Aug 14, 2013 10:15 pm
from the FSM
Post Posted: Fri Aug 16, 2013 11:11 am
So would i needa use the fourth plug for 4th gear(if thats what its for) or could i just take it off?
Post Posted: Fri Aug 16, 2013 11:27 pm
Why don't you put the Old box on the ground next to the New one and see which are the same plugs you will need? If your old box only used 3 plugs, then that is all you will need when using the new box.
My guess is the Neutral plug is the extra plug, as it was generally only fitted in cars with A/C for an idle up solenoid.
If the plug shapes are different, you can swap the plugs over by prying out the pins, but it's probably easier to just swap over the whole switches.
Post Posted: Sat Aug 17, 2013 8:41 am
red/yellow is reverse.
there are a 4th gear and a 5th gear switch.
The extra you have is a neutral switch. That gearbox came from a car that had AC.
Users browsing this forum: Google [Bot] and 84 guests
