It is currently Tue Nov 03, 2026 6:50 pm
Vehicle: Suzuki sierra sj410
Post Posted: Wed Aug 21, 2013 3:46 pm
Just wanting to know if and where I can purchase reduction gears for my 1 litre 4.89:1 maybe ?
Post Posted: Wed Aug 21, 2013 5:06 pm
Search function at the top is your friend
But since you're new.....
http://www.lowrangeoffroad.com/
Post Posted: Wed Aug 21, 2013 5:31 pm
If you have an early SJ410 with the non-4wd light transfer case you will need to find a switched transfercase. The non-switch transfer wont take aftermarket gears.
Post Posted: Wed Aug 21, 2013 5:40 pm
Thanks sideways just what i needed to know it is a non-switch what other option would u recommend if I can't find another case ?
Post Posted: Wed Aug 21, 2013 6:08 pm
For a non switched case you have 2 options. Find a switched case or stick with standard gearing.
Post Posted: Wed Aug 21, 2013 6:47 pm
So I take it a 1.3 case can't be adapted to fit?
Post Posted: Wed Aug 21, 2013 7:07 pm
Yes a 1.3 case will drop straight in. They are externally the same. But flanges are different and not interchangeable, so try and get the tail shaft flanges so you can run a half and half uni, or get a 1 litre switched case.
Post Posted: Wed Aug 21, 2013 7:12 pm
Thanks mrw82 that's helped me out heaps
Post Posted: Thu Aug 22, 2013 11:29 am
To my knowledge the flanges are interchangable
I got a 1.3L case and just swapped the flanges to fit my tailshaft/unis (they're all 1L with the smaller bolts)
Post Posted: Thu Aug 22, 2013 11:30 am
flanges from a switch type 1 litre will swap, non switch type wont
Users browsing this forum: Google [Bot] and 299 guests
