It is currently Wed Oct 21, 2026 10:25 am
Post Posted: Tue Aug 04, 2009 4:37 pm
Best Choice for the T/case?
Mine looked pretty grubby inside, so idea is to flush with something cheaper then drop it again then refill with a heavy duty?
Brands?
Anything you guys trust?
Dave
Vehicle: 1999 Jimny
Post Posted: Tue Aug 04, 2009 7:44 pm
PENRITE!!!!!!!!!!
Vehicle: Clown Car..
Post Posted: Tue Aug 04, 2009 7:59 pm
im considering this also.. i know im up for replacing the shifter bushing and am presuming all the broken bits are goin to be strewn thru the case, so was trying to work out what would be best to flush with.
I figured a CHEAP oil.. or diesel maybe(only as a flush-not to be driven with in!) Then refilling with VMX80 as its done WONDERS on the 5speed!
any other suggestions!??
Post Posted: Wed Aug 05, 2009 1:52 am
Been checking a few sites.. Transaxle 75 seems the go!
Post Posted: Wed Aug 05, 2009 12:40 pm
That's what I use. I've also got an additive in but can't for the life of me remember what it is.
Post Posted: Wed Aug 05, 2009 5:43 pm
If you can find it Redline Shock Proof is the sh*t, bit more expensive but does wonders for them. Burson auto parts are a distributor for this stuff. My case used to rattle very badly but with this in there it sounds much better. Will also change colour if overheated so..... If you are doing any work to your transfer you just collect your old oil, strain it and reuse it, it will be fine to use again. Extra long life, synthetic lubricant that has no petrochemicals so better for the environment as well...
Post Posted: Wed Aug 05, 2009 10:09 pm
Went for the Transaxle 75 and nulon Additive..
Added some to the front n back diff's aswell..
Service complete
Users browsing this forum: Google [Bot] and 109 guests
