It is currently Wed Oct 21, 2026 2:40 pm
Post Posted: Wed Aug 05, 2009 2:07 pm
When i really flex up the rear my springs jump out,
How can i stop this? i have seen those spring holders but wouldnt they stop flewing? also have seen bigger cups to hold them and long bump stops.
What is the best method?
Post Posted: Wed Aug 05, 2009 3:02 pm
sounds like you have coil springs, i would throw in some spring spacers.
Vehicle: 75 Cruiser
Post Posted: Wed Aug 05, 2009 3:41 pm
springs spacers wouldn't stop the springs falling out?
Can you clamp the springs at the bottom, so it doesn't matter if the diff drops away and the springs falls away from the top mount, they are still held at the base and return to normal when flexing back. That's the way i have mine set up.
There's a whole debate about clamping at just the base or both base and top.
Post Posted: Wed Aug 05, 2009 3:45 pm
if the vehicle is flexing and the spring is to short then it falls away, spacers bring the mount point closer to the spring so it should not pop out.
for example the jimny does not have its bump stop inside the spring at the rear so the spacer has to locate the spring on full flex or it will fall out.
Post Posted: Wed Aug 05, 2009 4:09 pm
retain them at the top
Post Posted: Wed Aug 05, 2009 4:33 pm
are spring spaceers any good. I was contemplating getting some 4 my vitara.. Just 4 some cheap lift til i can afford some propper lift..
Post Posted: Wed Aug 05, 2009 4:50 pm
are spring spacers legal? is there a difference between coil spacers and spring spacers or are they the same thing?
Vehicle: MY2019 Jimny
Post Posted: Wed Aug 05, 2009 5:15 pm
The coil is the spring, so they are the same.
Post Posted: Wed Aug 05, 2009 5:26 pm
are they legal??
Post Posted: Wed Aug 05, 2009 6:11 pm
so clamp? spacers? bumpstops lol
Post Posted: Wed Aug 05, 2009 6:32 pm
clamping them is the only way to stop them falling out in all situtions.
i just can't comment on how to clamp them best or if to clamp top only, bottom only or top and bottom.
my mates rangie is only clamped on the bottom and they return and seat really well after full flex. His is held with a small "strap" of metal bolted down to the spring plate.
weaves
Vehicle: Clown Car..
Post Posted: Wed Aug 05, 2009 7:09 pm
Joes on springs..in the Sierra... but same idea..looks to be retained at the bottom..Im sure he will chime in soon enough! :)
Post Posted: Wed Aug 05, 2009 7:19 pm
might be the way tto go, just make up a small strap like bit to bolt in across the bottom. might look at spacers to as i want more lift
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 189 guests
