It is currently Wed Oct 21, 2026 5:45 am
Post Posted: Wed Aug 05, 2009 11:46 pm
ok, the situation is that when the car is driving along and you slow down for traffic lights/turning, the engine stalls, basically whenever the engine goes from revving high to idle speed. Even when it's just in neutral, if you rev it then stop it stalls.
Do any of you reckon you might know what the problem is?
Post Posted: Wed Aug 05, 2009 11:51 pm
had the same issue heaps
its to do with the carby may need a service,
make sure auto choke is all workign and that ur idle speed is correct
i have had this a few times
zook carby's are a pain its a 6 monthly issue for me
Post Posted: Thu Aug 06, 2009 12:08 am
yeah sort of figured it was the carby, i already cleaned it all out and adjusted the idle speed, anyone know how i can adjust the choke? or what specifically might be wrong with it?
Vehicle: lj81 stockman
Post Posted: Thu Aug 06, 2009 1:02 am
it will be the idle solnoid blow it out and blow air up the hole to.check that it clicks when u turn the key.its on the engine side of the carby and has 2 wires comen out of it
the wobble rocks
Post Posted: Thu Aug 06, 2009 1:36 am
what gypsy said
tha was my issue put more clearly :)
Users browsing this forum: Google [Bot] and 147 guests
