It is currently Wed Oct 21, 2026 12:38 am
Vehicle: 30s front locker barwork
Post Posted: Mon Sep 22, 2008 10:37 pm
hey guys
i hav 215 75 15 tires on my seirra n i want to drop my low range lower than stock n high n 2wd back to stock is there any kits for this bcoz all the kits i hav seen r for bigger tires
Post Posted: Mon Sep 22, 2008 11:47 pm
if its a WT (3.7) you could go to NT (3.9) centres and gain a bit back.
but 215/75R15 is so close to stock its hardly work the effort. Only 15mm in diameter difference from my rough calculations.
Post Posted: Tue Sep 23, 2008 10:57 am
If you don't plan on getting any bigger tyres down the track, I'd probably go 4.16:1 transfer gears. Should be great off road. May rev a little harder on the freeway.
Post Posted: Fri Aug 07, 2009 12:11 am
*BUMP*
If I was to leave the F10a in (4 speed)
Would this option be a help or pain in the arse??
What are the tran gear options for the 1lt?
*Did have a look on search but couldnt really find the info i wanted*
Post Posted: Fri Aug 07, 2009 2:30 pm
I'm a little bit confused. It's always helpful if you provide all the details of your current setup when asking a question.
As you have an F10a and 4 speed, I assume you also have a 1.0 transfer case.
If you do, it already has the same high range gearing as all of the 4:1-4.9:1 transfer gears = 1.55:1
So you could fit transfer gears to roughly double your low range and there would be no effect on high range.
However, if your transfer case does not have a 4WD light, it can't accept any aftermarket transfer gears.
Hope that helps.
Post Posted: Fri Aug 07, 2009 3:27 pm
hey mate . Yeah sorry. You nailed the set up. 1lt with switch. .
Cheers for info think ill start a thread with each question listed next time. Try and cover all bases
Thanks
Users browsing this forum: No registered users and 225 guests
