It is currently Wed Oct 21, 2026 12:35 am
Post Posted: Thu Aug 06, 2009 11:49 pm
just got some new rubber bushes to go in and i want to look after these ones so i want to use the right grease on them.
ive got a tube a tube of these if they will be ok
Castrol APXT
A blue colored grease with enhanced tackiness for improved performance in operating conditions characterized by extremes of heat, vibration and dampness
Castrol EPL2
Chassis lube and wheel bearings.
navara on 33s. hopfully rear air locker soon
Post Posted: Fri Aug 07, 2009 12:05 am
Either one should be fine its only to let the pins slip rather than squeaking and improve the life of the bushes also gives better ride quality.
Good question. I just bought some grease for my bushes today aswell.
PBR rubber grease. States its a castor oil based grease. Expensive though 110grms for $14.
What you really want to know is does it effect the rubber long term?
I think CASTROL OPTITEMP LG is the go.
Compatible with elastomers based on synthetic materials (e.g. NBR, CR) and Nrbase as well as with rubber.
http://www.castrol.com/castrol/productd ... Id=6004156
SS
Post Posted: Fri Aug 07, 2009 12:07 am
when i greae my bushes before. i usto grease basicly the whole bush so it will be free for movement in anyway. then i put a little bit of grease on the shackle where the bush sits to always that to slide nice
Post Posted: Fri Aug 07, 2009 12:24 am
grease kills rubber!
pbr rubber grease is for brake seals!!!
castrol make a rubber grease, washes off though
Post Posted: Fri Aug 07, 2009 1:09 am
ok then how do i keep them lubricated?
Post Posted: Fri Aug 07, 2009 1:25 am
X2 :?:
Post Posted: Fri Aug 07, 2009 1:29 am
Try a lanolin base grease. As far as i'm aware its ok on rubber.
Have been using it for quite a while and have'nt had any problems.
Hard to wash out, sticks to everything. As its not for high temp applications it should be alright.
Cheers.
Post Posted: Fri Aug 07, 2009 1:58 am
X2 :?:
rubber is suppposed to grip the metal surfaces and twist with it, not slide over it
another reason why urethane is better :)
Post Posted: Fri Aug 07, 2009 2:50 am
ok then well it would still need to be lubricated so it twist in the springs?
Post Posted: Fri Aug 07, 2009 3:00 am
no, the rubber twists in itself
Post Posted: Fri Aug 07, 2009 3:03 am
oooooooooooo i see. so you recon i shouldnt grease them?
Post Posted: Fri Aug 07, 2009 12:53 pm
You can grease them, but they will fall apart in the not to distant future. I was always using rubber because of its greater flex but got sick of replacing them. now use urethane and has been all good since
Post Posted: Fri Aug 07, 2009 2:24 pm
will a rubber grease be suitable? im am guessing it would be?
Post Posted: Fri Aug 07, 2009 2:34 pm
rubber grease won't kill the bushes, but it's pretty useless in the application- it's too light.
Lanolin sounds like a good option of you want to experiment with lubrication
HOWEVER - grit and sand stick to grease, and will then make a grinding paste that will flog everything out anyway.
IMHO regardless of what you do, you'll need to pull everything apart once a year so so for a clean up/bushing replace anyway.
I have seen some very soft urethane, but I'm not sure what their life will be like.
Post Posted: Fri Aug 07, 2009 2:42 pm
im in the process of putting somwOME springs in at moment. so no lube is the way to go yer? hope so cause i dont want to go and redo it all again.
Post Posted: Fri Aug 07, 2009 2:48 pm
OME springs come with urethane bushes which benefit from grease or the squeaking will drive you insane.
They do not require any sort of special grease AFAIK - urethane isn't (basically) affected by grease.
Post Posted: Fri Aug 07, 2009 5:38 pm
About 3 months before my fixed ends split :) lasted years in teh shackles though and that was 40 duro, very spongy :)
Post Posted: Fri Aug 07, 2009 9:36 pm
Steve beat me to it. If you do want to try Lanolin though, there's a product called Lanotec. Should be able to get it from Ripco and the likes I think
Post Posted: Sat Aug 08, 2009 3:37 pm
Supercrap also sells lanolin based grease in tubs.
Users browsing this forum: No registered users and 246 guests
