It is currently Sun Oct 18, 2026 10:21 am
Vehicle: 2000 model Suzuki Jimny
Post Posted: Mon Sep 30, 2013 7:18 pm
Hey guys,
I have an interesting little query/question that i would like to ask. I currently have a Jimny running a TD80mm lift kit due to my standard suspension dying/sagging insanely haha
Now, I want to change my suspension setup around and was wondering if i could go back to standard spring (no lift) and use the 80mm lifted shocks?
Im not sure wether this would work, obviously not great, but just until i make some dollars to get some new shocks.
So would this work? or is it a stupid idea?
Thanks,
Joel
Online
Post Posted: Mon Sep 30, 2013 7:35 pm
I think we worked out that the TD shocks for the 80mm lift wer too long to work without bumpstop spacing.
Post Posted: Mon Sep 30, 2013 7:39 pm
Sorry, all i meant was
"Can i use lifted shocks with standard springs?"
Thanks,
Joel
Online
Post Posted: Mon Sep 30, 2013 8:23 pm
And that's exactly the answer I gave you.
Post Posted: Mon Sep 30, 2013 8:56 pm
So if I am understanding correctly they are usable as long as I work out the bumpstip spacing?
Thanks for your help,
Joel
Vehicle: Drover pickup turk
Post Posted: Mon Sep 30, 2013 9:06 pm
Correct. Otherwise you'll destroy the shocks from bottoming out.
I like the tuna here
Vehicle: Coil Sierra
Post Posted: Tue Oct 01, 2013 8:35 pm
You might even find the 80mm shocks will run out of compression on the road as the shock will shorten itself by 4inches. A loud thump will be noticed first. Ignoring it will lead to broken shock mounts.
Post Posted: Tue Oct 01, 2013 8:44 pm
And as the shocks work to keep the coils in place during articulation, without relocating cones on the springs mounts (or Landrover-style limiting straps), your springs could fall out with the longer shocks allowing more droop.
Users browsing this forum: Google [Bot] and 303 guests
