It is currently Fri Oct 30, 2026 3:30 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2
Vehicle: 1995 2.0V6 Vitara LWB
Post Posted: Mon Oct 07, 2013 10:53 am
DarkHorse wrote:
Nup - jacks, spanners, socket set, allen keys, circlip pliers, maybe a hammer/pry bar/other persuading device... nothing too exotic.
cool thanks dark horse :beer: i have a pretty extensive range of tools but would hate to get 3/4 of the way through and not have a special tool for a certain bolt of clip thingy 8O
now all im waiting for is a decent weather forcast :roll:
Vehicle: 96 vit hardtop
Post Posted: Mon Oct 07, 2013 12:37 pm
I did the GV steel diff swap, and installed a locker at the same time (spartan locker) just to confuse things up a bit.
I dont have exotic tools, and cant say it was too hard.
Its dead easy to do. And I know this becuase if I can do it, anyone can do it.
The hardest bit about it all is putting the 80kgs of diff on your stomach whilst you try and get it in place lying under the car with ur mate asking you if "you're ok".
No im not F**$ing ok you prick get under here and help !!
Sorry about that outburst.
That and getting the drivers CV in. FML. I dunno how you guys change the drivers cv trackside. Took me 1 hour to get in.
Other than that. its piss easy.
Post Posted: Mon Oct 07, 2013 9:42 pm
Stub axle conversion ;)
And it's not that heavy you big girl! Not pleasant by any means, but I managed to bench press mine up by myself... :toughguy:
Vehicle: 99 Grand Vitara
Post Posted: Tue Oct 08, 2013 8:09 am
I broke a driver side cv this weekend, couldn't be fucked to change it out even though I had a spare ready to go... I still haven't figured out a quick way to change it yet.. I think it's stub axle time like darkhorse said.
Do they weigh 80kg??
http://www.strictly4x4.com.au
Post Posted: Tue Oct 08, 2013 8:31 am
Hahaha. We can't all be jacked like you !
I'd love to do a stub axle conversion but I have not the welding skills to pull off such a feat.
Vehicle: 95 Suzuki Vitara V6 2.0L Auto
Post Posted: Tue Oct 08, 2013 12:33 pm
Not sure if you have already swapped the diff out Tassie Jeeper. But, it can be done on your driveway at 11pm at night with no exotic tools. Only problem I ran into was that the diff is freaking heavy and a bit of a bastard to maneuver in. However, I did it the hard way, in that I did not remove either of my hub assemblies, I left the CVs in the hubs, unbolted the CV flange on one side, and slid the the CV out of the other side, then the whole thing plonked out.
Also, the diff ratio for a 2.0L V6 1995 Vitara, AUTOMATIC is 4.8 (Manual is 4.6 i believe), just incase you haven't already found it. And if you are still chasing a Third member, I have one (Brisbane). My blown diff left the third member in tact, just the housing and spider gears were rooted.
Post Posted: Tue Oct 08, 2013 4:35 pm
Definitely don't weigh 80kgs.
As for the stub axle conversion..... once you do this I think you have to run a Vit bolt in CV shaft to get the correct length.....
Still need 2 different cv's but would be an easy track side fix.
I could be wrong tho.
Post Posted: Tue Oct 08, 2013 5:12 pm
Fark that's gay, I think I have a vit LHS CV here. I'll compare it to my GV one when I take it all out.
Post Posted: Tue Oct 08, 2013 5:40 pm
I don't think you do...All the CVs for the bolt on are the same length and spline. So if you did have to have a different one it would be from any vit wouldnt need to be a 26sp inner as all the hub sides have the same spline.
The top one is a 26 spline from a Grand Vitara The middle one is a weird random one The bottom one is a 22 spline from a Vitara
L DGV 26sp, weird random one, R 94 SV 22sp
Post Posted: Tue Oct 08, 2013 5:59 pm
Wtf with the middle vitara one lol, I've got a 26 spline from a SE Vit attached to a GV shaft and outer and I'm pretty sure it doesn't look like that hahah.
And you sure all bolt on ones are the same? Cause SE's are shorter than SV's and GV's
Post Posted: Tue Oct 08, 2013 6:05 pm
Pretty sure the only difference (from what I've read don't quote me on it) is the length that goes into the diff... Maybe the SEs are different Most of what I've read is based on SVs and GVs
Post Posted: Tue Oct 08, 2013 8:17 pm
We are talking about the passenger side bolt in CV Shafts..... The GV has a longer half shaft....by about 30mm I think.
I did a little measuring up a while ago and didn't think a GV one was going to work due to being longer...... Would need to widen the front wheel track for it to work properly......
I hope someone can prove me wrong....
Post Posted: Wed Oct 09, 2013 5:51 pm
Yep correct B4T, I measured about 40mm longer over the SE LHS CV. So not sure if it will be ok or not.
Post Posted: Wed Oct 09, 2013 5:54 pm
middle CV isn't a genuine SV one... the inner CV is mongoloid. :?
Post Posted: Wed Oct 09, 2013 6:12 pm
just an update front diff is still in the zook its been raining allot when im confident it wont rail ill pull it out and see whats broken and whats still good and replace as needed.
cheers "karlmarkiewicz" on the third i spose it depends on my diff centere.
Post Posted: Thu Oct 10, 2013 12:34 am
To backtrack a bit - I weighed the alloy diff that came out of Elwood and that was 23kg or so. Steel would be a bit worse, but I doubt it would be more than 35kg.
Post Posted: Thu Oct 10, 2013 9:17 am
Noooooooooooooooooooooooooooooooooooooooo way!
IT WAS 80KGS DAMN IT. (can we just go with 80 so I dont look like too much of a dweeb)
Yeah, 80kgs man. Bloody heavy thing!
:thefinger: :thefinger: :thefinger:
Post Posted: Thu Oct 10, 2013 9:23 am
Yeah looks messed, didn't think you could get SV aftermarket ones though???
Anyone know if you can buy aftermarket SE LHS CV's?
Post Posted: Thu Oct 10, 2013 9:47 am
it's not even that much, the complete one i sent west weighed 29kgs viewtopic.php?f=5&t=23448&hilit=weights+22
Post Posted: Tue Oct 15, 2013 11:18 am
i wonder how hard it would be to fab up a rear diff housing with the correct ends and braketry to replace the alloy piece of crap.
might need to find an alloy housing to look at.
Post Posted: Tue Oct 15, 2013 12:13 pm
chopped sierra front has been done before.
Post Posted: Tue Oct 15, 2013 12:18 pm
any idea where? some pics would help.
bigger rear diff center would be a nice upgrade too
Post Posted: Tue Oct 15, 2013 3:08 pm
JML was making Anvil housings a while ago. Not sure if he finished them but.
Vehicle: 92 WT Sierra
Post Posted: Tue Oct 15, 2013 6:51 pm
tanshi, found this sierra rear housing as Vitara front http://bbs.zuwharrie.com/content/topic,100689.20.html
Post Posted: Tue Oct 15, 2013 7:05 pm
yep, that's one of the ones i was talking about, will try & find the other one i was thinking of.
Post Posted: Sat Mar 22, 2014 2:09 pm
zook is in getting a new timing chain kit, water pump, clutch and 98 GV steel fron't diff cant wait
Post Posted: Fri Apr 18, 2014 10:25 am
finally got the zook back after a month in the shop and 40 hours of labor but she runs like a new car now and is so much gruntier with the fixed coil removing the low rev miss/bog
Users browsing this forum: No registered users and 504 guests
