| Author |
Message |
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Wed Dec 19, 2012 7:55 pm |
Chasing a drop pitman to fit a vitara power steering box. 2 or 3 inch drop would be good.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
jono165
Joined: Thu May 27, 2010 12:01 pm Posts: 834 Location: Melbourne
 Posted: Wed Dec 19, 2012 8:22 pm |
Calmini make one http://puresuzuki.com/kick_pitman_arm.htm IIRC these are about 17mm locker so if your diff is moved forward you may have steering binding issues. I believe the Jimny PS pitman arms also fit the Vitara PS box, they are both a koyo brand steering box. Im sure I read on here somewhere the splines are the same. This means you can track down a standard Jimny PS Pitman arm which has about the same drop as a sierra pitman arm. The other option is a jimny drop pitman arm http://www.jimnybits.co.uk/shop/jimny/s ... d_563.html
shep
 Posted: Wed Dec 19, 2012 9:18 pm |
Calmini are out of stock
christover1
 Posted: Thu Dec 20, 2012 6:04 am |
I think early Tarago vans have a suitable pitman arm. But You'd need to check that out, memory fails me.
shep
 Posted: Sun Dec 23, 2012 1:39 pm |
Every tarago I have looked at has R&P steering.
christover1
 Posted: Sun Dec 23, 2012 2:15 pm |
shep
 Posted: Sun Dec 23, 2012 2:35 pm |
That one fits a Sierra box, I need one to fit a vitara box.
christover1
 Posted: Sun Dec 23, 2012 3:20 pm |
shep wrote: That one fits a Sierra box, I need one to fit a vitara box. My apolgies, always thought they were the same. I'll crawl back into my box now
christover1
 Posted: Sun Dec 23, 2012 3:30 pm |
shep
 Posted: Wed Jan 02, 2013 9:11 pm |
christover1 wrote: http://www.xtremezuksoffroad.com/index.cfm/do/Parts.Display/SidekickTrackerX90.htm?parent=0&cat=5 Never got a email back so scratch that one as well
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Fri Aug 16, 2013 8:08 am |
Can any one confirm that a jimmny pitman arm fits a vit box and how much drop does it give over a vit pitman arm thanks
hass
Joined: Thu Feb 03, 2011 9:39 am Posts: 20 Location: North Brisbane
Vehicle: 89 Sierra
 Posted: Wed Sep 25, 2013 11:12 am |
Did anyone confirm the Jimny arm fits the vit box? I am in the same situation...
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Wed Sep 25, 2013 8:15 pm |
hass wrote: Did anyone confirm the Jimny arm fits the vit box? I am in the same situation... I thought jimny was the same spline as sierra
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Thu Sep 26, 2013 6:29 am |
Joe wrote: hass wrote: Did anyone confirm the Jimny arm fits the vit box? I am in the same situation... I thought jimny was the same spline as sierra  AFAIK Jimny box is identical to Sierra EXCEPT for the pitman spline and the pitman length.
mr.green
Joined: Mon Oct 26, 2009 10:30 pm Posts: 426 Location: Tamworth
 Posted: Thu Oct 03, 2013 8:49 pm |
vit and jimny arms are the same spline. jimny is similar drop to a sierra. I have now bought 3 jimny arms to fit to vit boxes fitted to sierra cars. $130ish dollars new from suzuki
got_bar_work
 Posted: Fri Oct 11, 2013 1:01 pm |
Do u know how much drop they give over a vit arm
tanshi
 Posted: Fri Oct 11, 2013 1:06 pm |
vitara arm is flat so i would say around 1-2 inches drop
tanshi
 Posted: Fri Oct 11, 2013 1:07 pm |
this is a jimny power steer box
hooki
Joined: Mon Jul 21, 2008 11:30 pm Posts: 1785 Location: perth, WA
 Posted: Fri Oct 11, 2013 7:32 pm |
Is there a specific year Jimny Power steering pitman arm that suits the Vitara steering box, or will any of them fit?
and sorry noob question, the benefit of having the drag like and tie rod more parallel is reduced bump steer?
stem1
Joined: Tue Aug 20, 2013 10:03 am Posts: 53 Location: Cairns
Vehicle: '90 Vit, 16b, high and wobbly,
 Posted: Sun Oct 20, 2013 2:31 pm |
If the pitman arm is lowered, wouldn't there need to be a similar drop for the idler arm? Is this done with a lowering bracket using the stock arm or another arm with the drop? Where do I get the bits to sort this? Thanks
atari4x4
 Posted: Sun Oct 20, 2013 2:37 pm |
this is talking about fitting one to a sierra w/ vitara power steering so no idler arms etc.
RIKSTR
Joined: Sun Apr 26, 2009 11:30 pm Posts: 1278 Location: Canberra
 Posted: Sun Oct 20, 2013 3:19 pm |
Can someone give me the measurement from hole centre to hole centre on this, I am after one that has just a bit more throw that a stock vitara.
stem1
 Posted: Sun Oct 20, 2013 3:24 pm |
Ok thanks. I've just been looking at the calmini site and they make no mention of these parts. Can you direct me to a thread that covers this issue? Thanks
atari4x4
 Posted: Sun Oct 20, 2013 3:49 pm |
there is no issue... this isn't relevant to a vitara owner, as i said above it's about a sierra with vitara power steering.
stem1
 Posted: Sun Oct 20, 2013 4:18 pm |
OK, I thought maybe I could improve the steering arm angles associated with the calmini 3" lift and the subsequent front tyre screeching when going over table top speed bumps. But if thats just part of the deal, then that's one more thing off my list! Thanks
atari4x4
 Posted: Sun Oct 20, 2013 4:42 pm |
sounds like you've got other issues to deal with, i highly doubt that your tyre rub issues is caused by steering arm angles.
mr.green
 Posted: Mon Oct 21, 2013 12:23 pm |
hey RIKSTA if your steering arms are made by sky, your having the same problem as I am with lack of steer angle. the jimny arm is 10ish mm longer (from memory than the vit so it doesn't make up the difference. I was a bit annoyed about this as I specifically asked sky if they were short enough to match the sierra pitman arm. my solution which i haven't got around to finishing yet is I bought a left hand drive Toyota tie rod end kit with the relay end so I could set it up like a 60 series cruiser where the drag link is tied to the tie rod and in turn its steering the knuckle from the inner hole instead of the outer (on the left hand side steering arm) to make this work I have to shorten my sky tie rod to fit the relay end and that's a job for someone else as I don't have the tools to do it......
RIKSTR
 Posted: Thu Oct 24, 2013 12:51 pm |
Thanks for that Mr.G. I have the trail gear RHD hi steer and when checking with the trail tough one it was slightly different. It seems that TT had designed it to work with the shorter throw of the Vitara arm. Its very close to working, but I could just do with a bit more. I think the jimny arm will fix the problem if it is longer by 10mm
rob45x
Joined: Mon Jun 04, 2012 10:09 pm Posts: 813 Location: Sydney
Vehicle: 92 sierra tintop, 88 WT sj50
 Posted: Mon Dec 02, 2013 6:08 pm |
I have a drop pitman arm that is currently fitted to a wt steer box. Will that suit your application?
