It is currently Thu Oct 22, 2026 5:03 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
Vehicle: WT sierra, GU CRD
Post Posted: Mon Oct 14, 2013 4:58 pm
I had a few heavy loads behind my Sierra including a similar sized tinny. I did a trip to Fraser with somewhere in the range of 400kg behind it and four people on board, like you say... common sense required.
Anybody tow a couple of jet skis behind a Sierra?
I don't think I would. Maybe-maybe if it was braked.
The boat ramp could pose problems with traction, jetskis being heavy and a sierra being light.
I love ZD30. :)
Post Posted: Mon Oct 14, 2013 5:08 pm
True that
Vehicle: 2013 standard jimny
Post Posted: Mon Oct 14, 2013 5:57 pm
G'day, I tow my 4.4 metre tinny on trips up to 350 km each way and have no dramas, admit that I cruise on 110 and not 130 but it does well. The fuel use does increase but it is still better than anything else I have owned even with that increase.
Like every trip it is your call on how safe you drive.
Have a good evening.
Vehicle: Suzuki Sierra Stockman
Post Posted: Tue Oct 15, 2013 1:36 pm
You cruise on 110 kpm in a sierra towing a 4.4 mtr tinny for trips up to 350k so I can assume you also have a fair bit of gear as well??? You running a commy V6 transplant???
Vehicle: 93 Sierra
Post Posted: Tue Oct 15, 2013 1:57 pm
Not sure about the weight of his tinny, but I have towed my camping trailer (around 450kg loaded) across the Nullabor and up to the top end of WA using a stock G13BA. Sat on 100-110kph in 5th most of the way depending on headwinds, and got it up to 125kph in 4th overtaking roadtrains. That was with 2 people, 2 dogs and a fully loaded Zook.
While the trailer actually tows very nicely and in some ways seems to tame the roadholding of my Zook, I wouldn't be advising towing anything heavier or more subject to wind sway. Sierras just are not heavy enough to put anything big behind them sensibly, hence their 450kg towing limit.
Vehicle: 95 SJ70, 96 Escudo v6
Post Posted: Tue Oct 15, 2013 2:26 pm
I cant find the tow rating anywhere for my NZ registered Samurai. But I have towed a few different loads with it on my 8x4 trailer, e.g Moving house oh and a trailer of dirt, without any drama's apart from being a bit slow. Stopping isnt much of a worry but then theres not enough road to get it up past 80kph when towing. Also the longest distance I would have covered would be 50km.
Once towed a Mitzi lancer on a dolly with a Ford Laser, now that was interesting/dodgy !!!!!!!!!!
Post Posted: Tue Oct 15, 2013 2:31 pm
How many kays? Mophs engine has been rebuilt so it is not tired
Jimny m13a stock gearing and tyres would do it.
I love ZD30. :)
Post Posted: Tue Oct 15, 2013 2:36 pm
115000kms from new and definatly not tired. But have you seen the roads here in Northland NZ? Any part thats flat or straight for more than 2 km is rare!
Post Posted: Tue Oct 15, 2013 2:39 pm
Negative to having seen NZ roads. Some of ours are flat as a tack though, get what you mean there.
I love ZD30. :)
Post Posted: Tue Oct 15, 2013 3:19 pm
Trailer is aprox 1200kg with override disc brakes and it towed fine at 80kph.
I now tow the same boat with my jimny
Users browsing this forum: No registered users and 322 guests
