It is currently Sat May 02, 2026 12:09 pm
Vehicle: 99 Grand Vitara
Post Posted: Sat Jun 01, 2013 6:22 pm
Hey guys,
I've got the air locker fitted now and obviously the air actuating shit is gone Armsup and that's what made the 4wd light go on, anyone know how to make it come on when I put it in 4wd now?
http://www.strictly4x4.com.au
Vehicle: 1999 Jimny
Post Posted: Sat Jun 01, 2013 6:46 pm
wire it direct to your locker power???
Post Posted: Sat Jun 01, 2013 6:54 pm
Won't that mean it'll only come on when the locker is on?
Post Posted: Sat Jun 01, 2013 7:27 pm
Fitted correctly, the locker won't lock in 2wd, I think.
Post Posted: Sat Jun 01, 2013 7:31 pm
yes it will... locker doesn't know or care what the transfer case is doing.
Post Posted: Sat Jun 01, 2013 8:18 pm
OH yep, that is right, brain was fogged.
Front locker only comes on if rear lockers in,
brain is workin again.
Vehicle: 1999 Jimny
Post Posted: Sat Jun 01, 2013 8:21 pm
Yep...... there is a wire to/ from the TFC isn't there?maybe wire into that.
Post Posted: Sat Jun 01, 2013 8:31 pm
wouldn't you want it to light up the 4wd light when you put it in 4wd rather just when engaging the locker. :?
Vehicle: JB420, APK416, A6G415, A6N415
Post Posted: Sun Jun 02, 2013 5:33 am
The easiest way is to leave the little air pump in place and plug the output line, the other way is to wire the 4WD light in the cluster directly to the 4WD switch on the transfer case - look for orange & black wires - one is black with an orange stripe, the other orange with a black stripe.
Post Posted: Sun Jun 02, 2013 10:04 am
Its even easier than that.
Bridge out the red and pink wires at the pump connector. This basically eliminated the pressure switch in the pump. As soon as you put the transfer lever into 4wd the light will come on.
The pump has a timer on it and it the pump does not reach its required pressure and close the switch it times out and switches off the pump.
Hope this helps.
Vehicle: Suzuki Grand Vitara
Post Posted: Tue Jun 04, 2013 3:48 pm
I was pretty surprised to find the motor bolted to the inside of the bumper given hoe important it is.... I did a google search and found mention in this thread of a cable tie zip lock mod..... Anyone know about this ?
http://suzuki-grandvitara.info/forum/vi ... .php?t=321
klutched wrote:
Hey guys,
Post Posted: Tue Jun 04, 2013 4:41 pm
That is so dodgy......It works but there are better ways of getting rid of the stupid air engagement. If your going to the hassle of pulling the front diff out to put a cable tie in it why not just replace the center?
Post Posted: Tue Jun 04, 2013 10:24 pm
Because cable ties are cheap & readily available - replacement centers are neither, and whilst I'm about it, don't they also require a change of axle or some hybrid axle stuff on the right side?
Post Posted: Wed Jun 05, 2013 7:00 am
Ideally... yes but ive been rnning with a locked front for quite some time wit the stock GV drivers side CV/axle withou any issues apart from a few snapped cv's. Diff Drop brackets help alot.
Post Posted: Thu Jun 06, 2013 11:45 am
Cheers b4t! Got it all going now :)
Post Posted: Thu Jun 06, 2013 11:58 am
asdsadsa
Post Posted: Thu Jun 06, 2013 5:34 pm
Glad to help.
Post Posted: Tue Oct 15, 2013 3:21 pm
B4T, will the bridge still work with the air actuator totally gone? Or do I need to keep the stupid thing?
Post Posted: Tue Oct 15, 2013 4:11 pm
Get rid of it......
Cut the plug off that goes to the pump and short the red and pink together.
I'd put up pics but don't have any.
Users browsing this forum: No registered users and 65 guests
