It is currently Wed Oct 21, 2026 3:22 am
Post Posted: Mon Aug 10, 2009 2:33 pm
I have been looking into welded diffs, i have seen people just weld the gears together and also put a small piece of plate in there to, i was wondering what was the strongest way to weld it?
Post Posted: Mon Aug 10, 2009 3:38 pm
as you have said. Also with a mig. or tig if you can get it in there.
I did mine with a mig. Shitload of weld
Post Posted: Mon Aug 10, 2009 5:05 pm
If you must weld a diff (which I wouldn't recommend) then do it this way...
http://www.island4x4.com/4x4tech/axle/weldeddiff1/
Post Posted: Mon Aug 10, 2009 5:32 pm
I have done it that way.
Its ok at 1st, then starts ratcheting and wears out the pin holes eventually waiting for a pin to dropout and/or smash gears = no good.
Maybe ok for the front. But not rear.
My rear is/was solid now. (my rear diff is totally fooked now from locked on 33's + snapped axle)
Post Posted: Mon Aug 10, 2009 6:54 pm
All this = Lockrite or if you count labour, then = an Air Locker
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Mon Aug 10, 2009 7:23 pm
tom, go to the d4x4 ramp day and i will give you a drive of mine so you
can see how good gearing is. until you fix your gearing your diffs are going to be consumables.
Post Posted: Tue Aug 11, 2009 12:12 am
will do
Users browsing this forum: No registered users and 151 guests
