Joined: Wed May 02, 2012 6:52 am Posts: 81 Location: Sandgate
Vehicle: 1990 swb vitara jlx
Posted: Sat Oct 26, 2013 10:01 am
Hey Guys
Have been having an on going issue with my 1990 swb vitara the clutch has been sticking i have been adjusting the cable and this has been fixing the issue but only for a week or so i have kept doing this every time i noticed the clutch sticking i have checked the lever off the side of the bell housing as i have broken one b4 but it is fine and hasnt moved my question now is it that the clutch cable has been stretching or is my clutch plate gone. i have now run out of adjustment on my cable and need to fix
Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
Posted: Sat Oct 26, 2013 3:50 pm
The cable is not affected by the type of loads you haul, rather the resistance of the clutch pressure plate.
Mine was starting to grind in the sheath, so I removed the cable from teh vehicle and sprayed heaps of Lanoline grease down the cable. Has improved it immensely.
Users browsing this forum: No registered users and 93 guests
