It is currently Sat Oct 31, 2026 2:30 pm
Vehicle: 2000 JX Jimny
Post Posted: Fri Oct 05, 2012 12:26 pm
Anyone have a phone number or something for MIC offroad?
Vehicle: 4wd
Post Posted: Fri Oct 05, 2012 12:44 pm
I see they closed there ebay store.
http://cgi6.ebay.com.au/ws/eBayISAPI.dl ... oad&_rdc=1
Watch out or you'll get sued.
Post Posted: Fri Oct 05, 2012 12:55 pm
Yeah I noticed that. Not replying to emails via there home page either...
Post Posted: Fri Oct 05, 2012 2:46 pm
You guys must look in the wrong places, i knew i seen it the other day still up.
http://www.ebay.com.au/itm/Suzuki-Jimny ... 3a7a41a645
Vehicle: suzuki jimny
Post Posted: Mon Oct 28, 2013 2:39 pm
Hi guys I need his number as I need to know if I can actually use the rear bar when towing I brought a jimny with his wing arm bar and it has a place for the tong but I want to know if I can actually use it first and whats it rated to he will not answer my emails grr
Post Posted: Mon Oct 28, 2013 6:56 pm
If you are worried, take it to a tow bar or trailer shop to check if it is safe.
I'm fairly sure the place no longer exists.
Vehicle: Suzuki Jimny 2009
Post Posted: Mon Oct 28, 2013 7:14 pm
Even if you can find them they would not be able to give you an answer. They are made in China and don't necessarily comply with any Australian standards. Having said that though I have their standard tow bar and all the welds look good. I have used it for recovery only (no towing) and it seems quite solid. My only issue was that both the tongue and tow ball supplied were imperial and useless in Australia. I also threw away the horribly undersized bolts they supplied and got a larger size grade 10.9 bolts all round.
As Chris says get it checked out by an engineer or a tow bar place. If properly attached the chassis my bet is that it will be OK. You probably also have a 50mm x 50mm hitch receiver on it which is the main reason I got it. You can buy a standard Aussie hitch to fit it.
Vehicle: 1999 Jimny with to much!
Post Posted: Wed Oct 30, 2013 7:47 pm
Marricville, Sydney is were the workshop is.
Have a look around the forum. A number of people have spent some coin buying parts off them. They should have contact details. I think someone N.T. way with a jimny spent alot of money from here.
Cheers,
Rob.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Nov 01, 2013 2:30 pm
Cheers,
Rob.
i only have their rear bar.
Post Posted: Fri Nov 01, 2013 3:02 pm
pretty sure he's thinking of squibby in NSW with the M18 jimny with all the MIC fruit + engineers cert. :wink:
Post Posted: Mon Nov 04, 2013 1:25 pm
thanks guys ill take the road runner to a toe bar place and see what they say cheers
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Nov 22, 2013 8:59 pm
all the MIC Offroad products for the jimny...http://www.aliexpress.com/store/group/J ... 06957.html
Users browsing this forum: No registered users and 209 guests
