It is currently Sat Aug 01, 2026 7:48 pm
Vehicle: Suzuki Jimny
Post Posted: Tue Oct 29, 2013 9:29 am
So I'm planning on building up my Jimny and am looking at a 2" lift and 2" body lift,
What kind of rubber can i fit under that?
Should I even lift body and suspension?
Sorry for the nooby questions
Thanks for the help!
Post Posted: Tue Oct 29, 2013 10:31 am
When you click on Suzuki talk there is a noob question section, if your at all concerned with being flammed, just ask it in there.
In answer to your question, thats 100mm of lift and im running 31s with less lift then that.
235s and a little bit of guard trimming will fit with 40mm sprung lift.
Post Posted: Tue Oct 29, 2013 10:48 am
Cheers,
Probably aiming for 31's anyway
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Tue Oct 29, 2013 2:19 pm
what 31zook said - I have 3" spring Lift and have 30's with slight scrubbing that requires a slight guard chop.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Oct 31, 2013 11:25 am
i run 30"s with 3" springs and 2" BL. i still get minor scrubbing in very crossed up situations but nothing you would think twice about driving right on through.
as above, chop chop is your best solution
Post Posted: Thu Oct 31, 2013 1:02 pm
I have 4" spring lift with new radius arms. 30" tyres fit fine and it drives better then stock
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Oct 31, 2013 5:41 pm
and thats without the front sway bar.
same here, proper springs do more than a sway bar anyway
Vehicle: Suzuki Jimny 2009
Post Posted: Fri Nov 01, 2013 8:26 pm
You will need to consider gearing as well with that tyre size.
Users browsing this forum: No registered users and 142 guests
