It is currently Mon Nov 02, 2026 2:28 pm
Post Posted: Wed Feb 01, 2012 2:47 pm
well my sierra carby has had it and just wondering if a carby off a g13ba swift or even a 1.6 g16a would bolt onto the sierra manifold cheers??
Vehicle: 95 Sierra Soft top
Post Posted: Thu Feb 02, 2012 2:07 pm
I cant see why not, the swift and sierra are both g13ba other words the same motor anless you have a 3cyl swift witch they are diff
Vehicle: SJ51T
Post Posted: Thu Feb 02, 2012 2:21 pm
i went to a wrecker to do the same thing. All the carbys i pulled off swifts had different bolt spacing to a sierra carb.
Post Posted: Thu Feb 02, 2012 3:07 pm
so is there any other cars that might have the same carby i am thinking maybe a ke70 as they run an aisin carb but unsure if it would fit any suggestions would be great
Post Posted: Thu Feb 02, 2012 5:55 pm
i got a webber for sale if that helps
Vehicle: 1985 SJ51T
Post Posted: Sun Nov 10, 2013 2:48 pm
so does anyone know if a swift g13ba carb will bolt onto a sierra manifold?
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Sun Nov 10, 2013 11:57 pm
No they do not, they have a totally different bolt spacing.
Also the throttle cable come in at the wrong direction..
Vehicle: Sierra sj80
Post Posted: Mon Nov 11, 2013 6:00 pm
viewtopic.php?f=5&t=43795
Post Posted: Wed Nov 13, 2013 7:13 pm
the earlier swifts : ie 1984-1988 use the same carby as sierra although a slightly different external configuration , internals are the same. the jetting is different though , the primary jet is a tad smaller, but the secondary jet is much larger , ive seen everything in earlier swifts from 117-141 secondary and everything in between , always see a 104 or 105 in a sierra nothing ever different , which made me curious as why so many different jets in the early swifts.
What i put it down to was the sierra in that era only come in 1 option , same engine , same gearbox , one configuration , whereas the swift would come in 3 cylinder and 4 cylinder , auto and manual , a multiple of different configs which each requires a different jetting to another.
Users browsing this forum: No registered users and 225 guests
