It is currently Sat Oct 31, 2026 2:28 pm
Post Posted: Mon Nov 11, 2013 9:34 pm
so cracked the shits with my 32/36 webber and decied to upgrade to a brand spanker!
old mate at the carby shop talked me into the 38/38 dges! runs fine at idle and whole fuckery its got some balls!
full noise 1st gear is fine
2nd is fine but towards the top end of second (havent checked exact revs)
and defiantly full pedal third it starts to chug then basically loose power (same as if the car was running out of fuel):/
just wondering if anyone knows what jets it should be running
read a bit on the net saying webbers like to run with about 3-3.5psi so its good to run a fuel regulator
does anyone know what the mechanical pumps (standard) put out?
Post Posted: Mon Nov 11, 2013 9:45 pm
3.5-5psi.
Post Posted: Mon Nov 11, 2013 9:49 pm
:( better put the lecy pump in then :(
Post Posted: Mon Nov 11, 2013 9:53 pm
anyone have any jetting ideas
Vehicle: 85 ' Drover
Post Posted: Tue Nov 12, 2013 10:54 am
Did the bloke at the carby shop supply the ones that are currently in it?
If so id be going back for different ones.
Vehicle: 4wd
Post Posted: Tue Nov 12, 2013 11:05 am
What about upgrading to a stock Sierra carby or even better efi.
Personally I'd be taking it back and getting my money back.
Watch out or you'll get sued.
Post Posted: Tue Nov 12, 2013 11:06 am
Lols at people who think webers are great and constantly complain about issues with them.
Post Posted: Tue Nov 12, 2013 11:26 am
Webbers were great and then they invented fuel injection. :)
You'd be better off with a vitara carb, wire up the choke and off you go.
Post Posted: Tue Nov 12, 2013 11:28 am
Post Posted: Tue Nov 12, 2013 12:00 pm
Well a webber is only going to work well if it is tuned well.
Post Posted: Tue Nov 12, 2013 1:45 pm
droverdave wrote:
Well a webber is only going to work well if it is tuned well, every three hours.
Post Posted: Tue Nov 12, 2013 2:27 pm
kenn wrote:
Geez, you must have had a good one! :D
Post Posted: Tue Nov 12, 2013 4:55 pm
Meh I ran a weber for around 3 years on the old donk. Never had an issue on road. How long have the rest of you sheep run yours for before you gave up? ;)
Post Posted: Tue Nov 12, 2013 5:02 pm
EFI mofo!
Vehicle: 4wd
Post Posted: Tue Nov 12, 2013 5:20 pm
I ran one for about 6 months.
Baaaaa
Post Posted: Tue Nov 12, 2013 6:43 pm
I ran mine for about 2 years and only got rid of it coz I got done over by a dodgy carby place. If you spend the time to learn how they work they are a great carby.
Post Posted: Tue Nov 12, 2013 10:58 pm
I agree, I had a pair of twin throat 45mm side drafts on my 180bhp Daty 1600 rally car but that was thirty years ago and the weight loss program that car was on to achieve 250 kph, was phenomenal. Now days you could almost do that with a hot hatch out of the box from the factory while listening to your iPod, though I doubt that what ever you're listing to would sound as good as the Webber intake noise of a worked L18 at 7500 rpm. :D
Post Posted: Tue Nov 12, 2013 11:26 pm
i ran a weber on my 1.6 (32/36 DGAV) and it ran spot on until the linkages wore out (about 2 years). The cost of having them replaced was about 1/4 the cost of converting to EFI...
I went EFI.
Post Posted: Thu Nov 14, 2013 3:58 am
The 38 is usually sold for 1.6 motors and tuned 1.3s. even so it sounds like it needs properly re-jetting to suit your motor. Does the car shop have a dyno?
Edit: you will need to get the fuel pressure set properly before you attempt any tuning.
Post Posted: Fri Nov 15, 2013 7:27 pm
the only car i've heard that sounded better was a twin webber twin cam L18
Post Posted: Wed Nov 20, 2013 12:20 am
If you want a sierra webber this is the only place to buy one. ive done 3 sierras now and not a drama.
http://www.thecarbyshop.com/
Post Posted: Wed Nov 20, 2013 8:34 am
38s are a great carby, once tuned for you engine, you will not touch it again, they go like stink hey.
Its hard to say what jets, like what engine, ignition, any head work etc then what are you looking for, moving to bottom mid or top end ?
The losing power does sound like a fuel loss problem, filters in good condition, pump working well ??
Have you removed all the crud from the inlet manifold under the carb ? stock they have two holes, cant remember, bout 24mm and 28mm, set for the stock carby, very restrictive when upping carb size, if that hasn't been removed, rip the manifold off, take the carb off, with the adapter in place, run a texta or whatever around the inside base, take the adapter plate off, and remove whatever is inside the mark you placed, this will give near twice the inlet size. This will make for a much better performance above what you have now.
Vehicle: vit1990
Post Posted: Wed Nov 20, 2013 10:00 am
And they do hiclones :rofl:
Users browsing this forum: No registered users and 230 guests
