It is currently Sun Nov 01, 2026 8:48 pm
Post Posted: Fri Nov 15, 2013 7:46 am
Hi guys,
89 wt soft top 1.3 sierra
Alternator out of 91 22r 2.4 hilux
Same brand alternator, plugs, mounts, pulleys and alignment, just a bigger body and about 80 amps I believe.
In the el falcon alternator thread they say to put a big wire straight from the output of the alternator to the battery. Now on the stocker is this the black wire off the top post that dissapears into a loom of wires underneath the battery area?
If so can I just leave that wire unplugged and free and run a new one off that top post of the alternator to the battery positive? Or should I follow it to wherever the hell it is that it goes and remove it?
Or can I just plug the new alernator straight into this wire? Or will it fry it?
Cheers fellas
Post Posted: Sat Nov 16, 2013 2:02 am
If you leave that wire in place make sure you tape the end and preferably find the other end and disconnect it - you do not want to short that to the chassis.
Post Posted: Sun Nov 17, 2013 4:39 pm
does anyone know where it goes to? i dont really want to have to cut apart the whole wiring harness shit
Post Posted: Sun Nov 17, 2013 8:37 pm
Is this going to run off the serria belt ?
bye
Post Posted: Sun Nov 17, 2013 10:25 pm
Ahhh - if you don't already know the answer to that, should you be attempting this conversion?
The output lead from the alternator (the one that connects to the stud) is wired to the battery positive usually via fuse or in the case of a Sierra I believe it's a fused link - it would take me less than 10 minutes to find the other end of that cable if I had the car in front of me.
Find the battery positive cable (not the one to the starter) and follow that - you'll find the other end of the alternator cable most likely at the next "junction".
Post Posted: Mon Nov 18, 2013 12:01 pm
Well its a v belt on the motor it came off so yeah I was just going to use the sierra belt. Cheers guys.
Users browsing this forum: Google Adsense [Bot] and 380 guests
