It is currently Sat Oct 31, 2026 3:41 pm
Vehicle: 98 Jimny
Post Posted: Mon Nov 18, 2013 9:26 am
does anyone know if Samuria CV'sand Axles will fit a Jimny?? or do i have any other options??
http://www.xtremezuksoffroad.com/index. ... =28&cat=12
http://www.lowrangeoffroad.com/index.ph ... pline.html
http://piranhaoffroad.com.au/product/se ... zuki-jimny
http://www.trialjimny.com/axle.html
Post Posted: Mon Nov 18, 2013 10:06 am
Samurai ones wont fit, the actual CV will but the Axle shaft is the wrong length.
HOw much of a hurry are you in?
Vehicle: 98 Jimny
Post Posted: Mon Nov 18, 2013 10:21 am
not a massive hurry at all
Post Posted: Mon Nov 18, 2013 10:29 am
No, Sierras have different axle lengths.
You can get Jimny Chromos but they're very expensive. There's a few threads on here about jimny chromos. A while ago 31zook got a bunch of custom hituff axles made up so people could run chromo Sierra CVs with these stronger axles. Maybe send him a PM asking if he's planning to do another run of them.
From memory 31zooks setup cost around $1k. Well worth it to have a reliable front end. Jimny CVs share their internals with LJ CVs which were originally designed for a 600kg, 25hp vehicle (and they weren't even particularly strong there) so they're well and truly out of their depth on a modified Jimny.
Edit, beaten.
Vehicle: 98 Jimny
Post Posted: Mon Nov 18, 2013 3:23 pm
didn't 31zook get around that buy making a spacer ?? i have read that whole thread and i understand most of it.
Post Posted: Mon Nov 18, 2013 3:35 pm
No, custom axles and a spacer are needed.
I believe the "hot" setup would be to trim the CV down and use different wheel bearing nuts, thus giving no requirement for the spacer. You'd still need custom axles though. You'l probably have to convert to 26 spline side gears, If you're chasing strength then there's no point in keeping the 22 spline setup.
Vehicle: 98 Jimny
Post Posted: Mon Nov 18, 2013 3:40 pm
if i was to do this i would have to change the vacuum hubs to manual hubs??
Post Posted: Mon Nov 18, 2013 3:41 pm
yep i believe so, but then most people want to do that mod any way.
Vehicle: 98 Jimny
Post Posted: Mon Nov 18, 2013 3:44 pm
is it very hard or expensive to do the conversion??
Post Posted: Mon Nov 18, 2013 3:59 pm
//viewtopic.php?f=5&t=29951&hilit=jimny+manual+hub+conversion&start=30
Post Posted: Mon Nov 18, 2013 4:05 pm
Don't see why you couldn't keep the vacuum hubs, they are of unknown strength though.
Vehicle: 98 Jimny
Post Posted: Mon Nov 18, 2013 4:12 pm
i have had problems with them when i went out in the bush near brizzy i had to winch heaps to get out of there :(
Post Posted: Mon Nov 18, 2013 4:49 pm
You can remove your wheel bearing nut and trim it down. You only need to take about 8-10mm off the end of the CV shaft and a FWH bolts up.
I built a set of HyTuff 22pline axles sets, broke mine, and tim has a twist in his. Moral of the story is they need to be 26spline to work/be strong enough.
As for the front diff center, mine has be good to me, the ring gear anti-flex bolt has some rub marks on due to heaps of pressure going through it. But I read somewhere that the front diff the way its cut pulls into itself when going forward making it incrediably strong. But it a bit glassy in reverse.
Vehicle: 98 Jimny
Post Posted: Mon Nov 18, 2013 10:12 pm
hey 31zook would it be easier if i just bought the sierra hub to jimny conversion kit ??
Post Posted: Mon Nov 18, 2013 11:50 pm
Yeah. You might get away with running vac hubs but there a bit unreliable at times...
Vehicle: 98 Jimny
Post Posted: Tue Nov 19, 2013 6:36 am
do you know if Ben T still is selling stuff??
Post Posted: Tue Nov 19, 2013 8:16 am
Ask him?
Users browsing this forum: No registered users and 409 guests
