It is currently Mon Nov 02, 2026 3:02 am
Vehicle: Suzuki Sierra 1996 SJ80
Post Posted: Mon Nov 18, 2013 6:02 pm
does anyone have an exploded and labelled view of a 1.3L carby?
which screw is the idle screw?
cheers
Vehicle: WT sierra, GU CRD
Post Posted: Tue Nov 19, 2013 10:27 am
There is a download for the FSM that has all the info you will need.
http://www.suzukiinfo.com/
Idle mixture screw is capped with an aluminium fitting to prevent adjustment by the owner. A tool is available to adjust, or cut off the cover.
It is visible looking over the rocker cover from the RHS of engine bay.
Whats the reason for you needing to adjust it?
I love ZD30. :)
Vehicle: Drover pickup turk
Post Posted: Tue Nov 19, 2013 11:02 am
I'd say he would want the idle speed screw not the mixture screw.
In either case the FSM will help.
I like the tuna here
Post Posted: Tue Nov 19, 2013 11:24 am
yeah looking for the diagram mostly. carby not wrking well. just keeps stalling or idling too high
Post Posted: Tue Nov 19, 2013 11:26 am
thats often down to blocked hoses that run the auto choke
Post Posted: Tue Nov 19, 2013 2:21 pm
How do you unblock em?
Users browsing this forum: No registered users and 101 guests
