It is currently Sat Oct 31, 2026 4:45 pm
Vehicle: Suzuki jimny, WT sierra, GTR.
Post Posted: Mon Nov 25, 2013 6:00 pm
Hey guys, i bought a t-case with 6.5.1 gears fitted to it. It came with a rocktoy ring already fabbed up ready to fit. I have just test fit it and the roktoy hits the transmition tunnel, i have taken some measurements and believe with a bit of massaging ;) and cutting into the roktoy it will fit, I cant run a body lift as im getting the car engineered and its already sprung over. The rocktoy ring is 6mm thick. I have attached a picture of what i propose to cut, do you guys think this is too much and that it will effect integrity of the ring.
Post Posted: Mon Nov 25, 2013 7:16 pm
I have cut mine worse then that and havent had any dramas, but I do have a custom cradle.
Post Posted: Mon Nov 25, 2013 9:54 pm
Yea, didnt think there would be any dramas. Even with this cut of there is still a chance it won't fit, but I hope it does!
Post Posted: Tue Nov 26, 2013 2:32 am
I had to trim around the input shaft/top of the ring on my zook as aswell as the point you have marked.
Post Posted: Tue Nov 26, 2013 5:26 am
You will also need some on the drivers side
Post Posted: Tue Nov 26, 2013 3:41 pm
Yea, ill guess ill keep fitting ,marking and grinding till I squeeze it in.
Post Posted: Tue Nov 26, 2013 5:30 pm
Thats the other place mine is cut too.
Post Posted: Tue Nov 26, 2013 7:59 pm
You'll need to cut abouts all to top off to clear.... I did it in mine and still going strong but still hits te floor... If you got the time and skill cut the floor and make a bulge in it to clear the ring
Post Posted: Fri Nov 29, 2013 12:52 pm
Almost in! Moulded the tunnel a bit with some brute force and a hammer. And a little more trimming of the ring and she will fit. I guess even with 2/3rds of the thickness of the ring removed from the top will still be a lot stronger than the standard mounts.
Post Posted: Fri Nov 29, 2013 7:01 pm
It'll self clear after a couple of runs
Users browsing this forum: Google [Bot] and 77 guests
