It is currently Sun Nov 01, 2026 10:21 am
Post Posted: Thu Nov 21, 2013 9:47 pm
Any one know how to correct castor with the calmini arms? they apparently are meant to have castor and camber correction built into then but with 2 camber bolts in each strut maxed out I have neg castor and still some camber.
I know B4Vs does a castor correction bush which would be awesome but i don't think they would fit the calmini arms.
Anyone know the dimensions of the bushes calmini use? can a castor bush from a different car fit?
Post Posted: Wed Nov 27, 2013 10:40 pm
Any one? Looking for the dimensions of the calmini rear control arm bush so i can try find an offset castor bush to replace it with.
Post Posted: Thu Nov 28, 2013 5:11 am
I dont think castor has ever come up, sure youve got the arms in the right way?
Post Posted: Thu Nov 28, 2013 5:44 pm
How can you put them in the wrong way? they can only go in one way to line up the spring perch and ball joint...
Post Posted: Thu Nov 28, 2013 6:38 pm
Check ur towers r not bent out of shape
Post Posted: Thu Nov 28, 2013 6:43 pm
nope nothing is bend, all new struts and springs haven't helped... towers are straight
Users browsing this forum: No registered users and 329 guests
