It is currently Mon Nov 02, 2026 9:47 am
Post Posted: Thu Nov 21, 2013 9:49 pm
Any ones toyed with adjustable elongated ones that fit? I know ninja had the calmini adjustable one but haven't heard if it did anything to help or was even used.
Vehicle: 2002 Suzuki XL7
Post Posted: Fri Nov 22, 2013 9:26 am
Mine are longer extended arms with around 40degree bend towards the end, has given heaps of flex in the rear but it looks as if the rear wheels are further back eg not centered in the arch, it also has kept the Diff level, before it was on a angle pointed upwards.
I have a adjustable pan rod and it was a pain in the ass always tightening it. I gather it would be worse on trailing arms, would hate to think if one rattled apart on a corrugated road.
Post Posted: Fri Nov 22, 2013 12:13 pm
Where did you get the longer arms? im happy to have it pushed back as with the rear bar there is unlimited room in the back only the front of the arch is limiting.
Do the gv and xl7 run the same arms?
Post Posted: Fri Nov 22, 2013 12:26 pm
Yep they run the same arms.
I got them from Giz around 4 years ago with the pan rod, they still sell them, They fit the standard size bushes too which i get of ebay.
I will try and find the photo of when i installed them and post it. You can attach the brake line to it as well but ive got them upside down and back to front to allow more clearance and alot more travel. They also do the upper arms to which are adjustable to vary the tilt of the diff if going 4" and above.
Post Posted: Fri Nov 22, 2013 7:15 pm
Yeah I'm running the calmini adjustable ones mate but I wouldn't recommend them - I've actually got them set to being pretty much the same length as stock and they are all but maxxed out.
I presume the SWB GVs must use shorter arms and they are specifically designed for them, as really the only adjustment you get on the wagons is to make them shorter than standard.
Haven't had any issues with them coming loose at least, but yeah I definitely wouldn't buy them again knowing what I know now. The GIZ ones sound like the ticket.
Post Posted: Mon Nov 25, 2013 8:19 am
Adjustable Upper pitman arm.
Lower Pitman arm (mine doesnt have as long brake line attachment)
I use Ultima Comodore Wagon HD Shocks not what i ordered but ended up better than what i ordered, Much bigger bore and for 4wd use, stacks of flex, and not a bad ride, great for towing.
Standard height and flexed height
Post Posted: Mon Nov 25, 2013 11:15 am
http://en.wikipedia.org/wiki/Pitman_arm
Post Posted: Mon Nov 25, 2013 11:37 am
haha yes yes Fordem. Thats what Giz Call them.
Suzuki call them Lateral Rods, others call trailing arms.
Post Posted: Mon Nov 25, 2013 9:15 pm
I believe you are confused.
Suzuki calls the trailing arms - rod assy, suspension upper & lower - what they call the rod assy, suspension lateral is commonly known as the panhard rod or track bar.
Post Posted: Thu Nov 28, 2013 2:30 pm
Found the pictures finally. This is when i received them and installed them. (Please ignore the bricks holding up my car :oops: )
Post Posted: Thu Nov 28, 2013 5:53 pm
Nice they look the goods and a bit longer, but i can't find them on the GIZ site!
Post Posted: Thu Nov 28, 2013 6:36 pm
Is that arm up side down
Isn't the bend to help ground clearance not make it worse
Post Posted: Thu Nov 28, 2013 6:41 pm
I think the bend is to help it slide over things, flipped it would get hung up easier i think...
Vehicle: Which one?
The tab on the "bottom" in that case would be kind of stupid though, right?
Post Posted: Thu Nov 28, 2013 7:49 pm
It's ment to be installed how i did it first in pic but I have it back to front and upside down now for more clearance they designed it like that to keep wheel centered on full flex I think There not on site have to ask for them.
Post Posted: Thu Nov 28, 2013 7:51 pm
Oh and I took the tab off
Post Posted: Thu Nov 28, 2013 10:00 pm
I don't see how the bend will keep the wheel/axle centered - it's rotating around a fixed point on the chassis, and the effective length doesn't change - so the axle moves in the same arc regardless of the shape of the arm.
Post Posted: Thu Nov 28, 2013 11:00 pm
Any one know any other places that have them or ones that would fit and possibly be longer still?
Post Posted: Fri Nov 29, 2013 9:05 am
How high do you want to go lol? I measured a max lift on the XL of 6.5" before everything is stretched to its limits Wheels was still roughly center in the arch, but gather you want longer to move them back so can fit larger tyres? I will measure the distance between the front of arch to center of hub.
I am wondering but its a guess if Nissan Patrol arms would fit? eg http://snakeracing.com.au/store/nissan- ... 1a3618d269
Would have to measure bush size and bolt hole size. I gather they will be either to wide a bush or diameter to large.
Post Posted: Fri Nov 29, 2013 10:42 pm
haha yeah im at 4.5in in the rear of suspension lift, just want to move it back for larger tyres. I thought about some other adjustable ones for larger cars and making them short to fit. I was thinking around 30mm with a tailshaft spacer. at full flex the wheels are pretty much moved forward to the arches and thats just 225s
Post Posted: Sat Nov 30, 2013 8:07 am
Go grab a second hand stock pair and chop them up add the length you need!
Darkhorse made his own.
Users browsing this forum: No registered users and 388 guests
