Does anyone know where to get the rubber strip for the flares? My vit is a 98 J20 with the factory flare/mouldings. I have removed one (ok, it fell off) and have got some clips and christmas tree clips to re fit it, but the little rubber strip that stops crud going down between the guard and the flare is as hard as rock (brittle) and broken. I would like to replace it before I put the moulding back on if I can find some. I am on sunny coast, Qld.
Bear in mind that from memory, SV vitaras use a custom moulding that follows the shape of the guard. It is quite brittle even when new because it doesn't have to bend like generic material. The generic material won't look like the factory product because of this. (And the factory stuff was coloured the same as the flares, not black)
Users browsing this forum: No registered users and 420 guests
